Do I Need a Proportioning Valve? #174098
12/24/08 01:49 PM
12/24/08 01:49 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
72 Cuda drums all around. Have a power booster with M/C laying around.
Grandma always said I had "hands of gold"!
Re: Do I Need a Proportioning Valve? [Re: CHRGR69] #174099
12/24/08 01:56 PM
12/24/08 01:56 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Yes
If not it will always hit fronts first.
Since they are the closest to the M/C
Re: Do I Need a Proportioning Valve? [Re: cyphre666] #174100
12/24/08 07:41 PM
12/24/08 07:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes
What? Someone has no idea about hydraulics here.
No, in an all drum setup you do not need a proportioning valve.
Don't be the exception.
Re: Do I Need a Proportioning Valve? [Re: Supercuda] #174101
12/24/08 08:04 PM
12/24/08 08:04 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Yes
Even with the booster?
Re: Do I Need a Proportioning Valve? [Re: CHRGR69] #174102
12/24/08 08:30 PM
12/24/08 08:30 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Bosster just makes the pedal easier to push, dosent affect the actual hydraulics of the master cylinder.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Do I Need a Proportioning Valve? [Re: 70dart360] #174103
12/24/08 09:39 PM
12/24/08 09:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Correct. Also the pedal leverage is different manual vs power assist.
Don't need as much leverage with power assist and you need more with manual. Which is why there is more pedal travel with manual brakes. All the booster does is make it easier on your foot, pressure out of the M/C is the same, roughly.
But neither have anything to do with proportioning.
Re: Do I Need a Proportioning Valve? [Re: Supercuda] #174104
12/25/08 12:05 AM
12/25/08 12:05 AM
cyphre666 Offline
cyphre666  Offline
I guess ALL the manufacturers are wrong.
Why have a proportioning valve at all ?
So it evens out the pressure from the front
to the rear.
Hydraulics,
Closest to the first point of contact.
Yes
Re: Do I Need a Proportioning Valve? [Re: Supercuda] #174105
12/25/08 12:12 AM
12/25/08 12:12 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
Nop....no valve needed!
I ran 1/8th mile (6.40's & 6.50's) in a 3200 pound B-body for years with all drum brakes, no booster of course & no prop. valve and never had an ounce of trouble out of it.
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Do I Need a Proportioning Valve? [Re: cyphre666] #174106
12/25/08 12:33 AM
12/25/08 12:33 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
to the rear.
Hydraulics,
Yes
Cause when you hit the brakes the master cyl applies pressure to the rears first, its designed that way. Wont need a prop vale until disc brakes are added. All the 4 wheel drum brake cars had a junction block, not a prop valve.
Re: Do I Need a Proportioning Valve? [Re: 70dart360] #174107
12/25/08 04:05 AM
12/25/08 04:05 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Here's a pic of the four wheel drum distribution block that I am using for my four wheel disc conversion. The car originally had front disc rear drum AND a factory proportioning valve, which had to be removed. Properly designed and balanced brake systems that have either four wheel drums or four wheel discs use distribution blocks.
The "proportioning" of the brake bias from front to rear is governed in general by the size of the caliper bores in relation to each other. Rotor and pad size and composision also plays a role.
A proportioning valve is typically used in an attempt to balance the proportion of front to rear brake power. In general, it is a bandaid for a less than ideal brake design such as matching front discs to rear drums. In certain cases it can be a useful tool to balance the proportioning of brake bias during races to compensate for changing fuel loads, track conditions, tire wear etc.
Re: Do I Need a Proportioning Valve? [Re: jbc426] #174108
12/25/08 10:00 AM
12/25/08 10:00 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yup, and that's why I'm going to be looking for one to put on my Dakota. originally power disc/drum, it's now manual disc/disc but my truck is a 98...in 03/04 they upgraded to bigger discs, and 4wheel discs. that's where I got the rear discs from...and thye are actually LARGER than the fronts, although brake pad contact looks to be about the same.
however, since it's a truck and all the weight is up front, I'm gonna need a prop valve until I can find a set of front discs to match my new rears, that way I'll have larger discs with a larger swept area up front, and will be able to dial down the front bias for more even hydraulic distribution on the brakes.
if you are having trouble with fronts locking up first, or rears locking up first, you can adjust the bias with a prop valve for even braking. if all 4 lock up at the same time, then you can maximize your braking by getting the most out of each corner before one locks up and either kills your steering or brings the back end around.
**Photobucket sucks**
Re: Do I Need a Proportioning Valve? [Re: cyphre666] #174109
12/25/08 10:43 AM
12/25/08 10:43 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
to the rear.
Hydraulics,
My advice to you is to do some research before you speak. The only one wrong here is you. The M/C is designed to build pressure to the rear brakes before it can build pressure to the front, at least on a dual reservior setup.
Show ONE factory Mopar all drum setup that uses a proportioning valve.
As for disc/drum combos the factory combination valve does more than just proportion. Disc and drum setup have different operating characteristics and the factory combination valve is an attempt to harmonize the two.
Sometimes it works, other times (A bodies) it doesn't work so well.
All disc setups shouldn't need proportioning valves but sometimes the system is not optimal, think parts sharing across platforms.
Re: Do I Need a Proportioning Valve? [Re: Supercuda] #174110
12/25/08 12:53 PM
12/25/08 12:53 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Sorry to hijack the thread, but am I reading you correctly that a factory combination valve is better to use in a disc/drum combo than a proportioning valve? Or would they work about the same?
Re: Do I Need a Proportioning Valve? [Re: 68Bullit] #174111
12/25/08 01:19 PM
12/25/08 01:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can use the factory combination valve, which combines a fixed, one-size-fits-all proportioning valve along with some other features, and you can plumb an adjustable proportioning valve behind the combination valve for added adjustability of rear brakes.
Re: Do I Need a Proportioning Valve? [Re: jbc426] #174112
12/25/08 03:21 PM
12/25/08 03:21 PM
Eberg suggested in his Mopar Action articles to iirc toss the factory one & add an adjustable one in the rear line & I went with that but a guy here said this would cause the fronts to wear excessively(which makes sense) because the fronts(discs) are going to hit before the drum linings are even in contact) & (for an A body) to use a M body proportioning valve(2 different M ones available). When it's right should a person jamb on the brakes & have 4 equal patches of rubber???
Re: Do I Need a Proportioning Valve? [Re: RapidRobert] #174113
12/25/08 10:51 PM
12/25/08 10:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Eberg suggested in his Mopar Action articles to iirc toss the factory one & add an adjustable one in the rear line & I went with that but a guy here said this would cause the fronts to wear excessively(which makes sense) because the fronts(discs) are going to hit before the drum linings are even in contact) & (for an A body) to use a M body proportioning valve(2 different M ones available). If it's right should a person jamb on the brakes & have 4 equal patches of rubber???
That person would have been me.
The factory combination valve is a critical part of a disc/drum combo. If you have issues with rear brake lockup then you can plumb an adjustable proportioning valve into the rear brake line to fine tune the proportioning, or you can change wheel cylinder sizing, go smaller. Not running a combination valve merely shows the lack of understanding what the combination valve gives you in addition to proportioning.
My particular combo, which has worked great on two A bodies and an M body is the 11.75" rotor and 11" drum combo running an M body proportioning valve from an M with 11" rear drums, not 10". They are different, and different for a reason. For a master cylinder I have used both the aluminum two bolt M/C from an M body or the A body four bolt M/C, both for disc cars.
Re: Do I Need a Proportioning Valve? [Re: Supercuda] #174114
12/26/08 07:27 AM
12/26/08 07:27 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
The factory valve is just a distribution block. Period!!!! It has the valve inside but its only for the brake light in the dash.
Re: Do I Need a Proportioning Valve? [Re: farmington] #174115
12/26/08 10:13 AM
12/26/08 10:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Only in an all drum setup, which will NOT work when swapping discs up front.
Re: Do I Need a Proportioning Valve? [Re: Supercuda] #174116
12/26/08 12:59 PM
12/26/08 12:59 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
could someone explain why my 70coronet brakes perfectly with NO prop valve at all? i put an 73up A body disc setup up front and retained 10 inch drums in back. i was going to get an adjustable one but since it drove fine been about 5 years now. are my drums maybe just pooched? i've been curious about it ever since. sorry to hijack.
Re: Do I Need a Proportioning Valve? [Re: dirtybee] #174117
12/26/08 01:08 PM
12/26/08 01:08 PM
My 65 dart(318/904/7&1/4) w 73 discs(76 2.70" calipers as opposed to 73-75 2.60" ones) & 10" drums on the 7&1/4, I didn't use a prop valve when I put it together & it stops fine(around town) though I have not had the displeasure of having to do a panic stop. I sold the car & I'm buying it back this weekend so I am going to check the pads/linings & see what I see
