Page 4 of 5 1 2 3 4 5
Re: bigtimeauto / Alterkation users? [Re: fishy340] #1739631
01/31/15 08:59 PM
01/31/15 08:59 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Why make em longer ? Bigtime and a few others prove the system works..only upgrade is put a better coil over in.
Um I had zero issues w my Cuda that didn't or doesn't make 2500hp.
I agree with Gary at 140mph It felt like a cruise
Because not everybody has a 2500 hp car like bigtime. A slower car like 10.50-11.50 would like a little more pitch rotation to get it planted. Only the high hp car like limited travel. Unless your a four link or ladder bar car, then you also don't mind the little travel.
WOW DIDN'T KNOW YOUR CUDA WAS A 10.50 CAR!!!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: bigtimeauto / Alterkation users? [Re: 1967dartgt] #1739632
01/31/15 11:13 PM
01/31/15 11:13 PM
USA
Low Deck Offline
Low Deck  Offline
USA
The HDK K-member is one I have looked at too. They use an upper shock mount support.
Re: bigtimeauto / Alterkation users? [Re: Low Deck] #1739633
01/31/15 11:24 PM
01/31/15 11:24 PM
USA
Low Deck Offline
Low Deck  Offline
USA
I think the QA1 k-member keeps the torsion bars.
Re: bigtimeauto / Alterkation users? [Re: Low Deck] #1739634
01/31/15 11:38 PM
01/31/15 11:38 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, this is all amazing info. Thanks so much.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: bigtimeauto / Alterkation users? [Re: Low Deck] #1739635
02/01/15 12:47 AM
02/01/15 12:47 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
HDK upper shock support
I'm curious, what car do you have, do you race it? How fast is it and what suspension is under it.
thx, bob
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739636
02/01/15 01:03 AM
02/01/15 01:03 AM
USA
Low Deck Offline
Low Deck  Offline
USA
I have a 340 Dart that is under construction (it has been for a long time). and will be a 400/470 727 TF when it gets done. I had bought Schumacher conversion mounts but unless anything better shows up it will eventually have the HDK suspension. I want to be able to utilize full sized B/E under chassis headers with nothing in the way which a coil-over conversion will allow me to do. I have two friends with four HDK Hemi A-bodies between them. All are street cars and work really well. Their rides are comparable to a well tuned stocker and the steering is vastly improved. One of those cars has A/C and another one of them has a Keisler 5- speed. Two of them have Hilborn stack injection with EFI and two have Dana 60's. I do not plan on racing my car although it would be nice to try it once just to see what it can do.
Re: bigtimeauto / Alterkation users? [Re: Low Deck] #1739637
02/01/15 01:12 AM
02/01/15 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a 340 Dart that is under construction (it has been for a long time) and will be a 400/470 727 TF when it gets done. I had bought Schumacher conversion mounts but unless anything better shows up it will eventually have the HDK suspension. I want to be able to utilize full sized B/E under chassis headers with nothing in the way which a coil-over conversion will allow me to do. I have two friends with four HDK Hemi A-bodies between them. All are street cars and work really well. Their rides are comparable to a well tuned stocker and the steering is vastly improved. One of those cars has A/C and another one of them has a Keisler 5- speed. Two of them have Hilborn stack injection with EFI and two have Dana 60's. I do not plan on racing my car although it would be nice to try it once just to see what it can do.
If your still building the car, why not put a pair
of struts on it for MUCH cheaper
Re: bigtimeauto / Alterkation users? [Re: MR_P_BODY] #1739638
02/01/15 01:27 AM
02/01/15 01:27 AM
USA
Low Deck Offline
Low Deck  Offline
USA
I've never seen anybody convert to struts on a street car.
Re: bigtimeauto / Alterkation users? [Re: MR_P_BODY] #1739639
02/01/15 01:38 AM
02/01/15 01:38 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
like I have pointed out to you before, CHEAPER is not better. (even if the struts would actually end up cheaper) You want people to put struts on cars without a jig, frame table or the skill set to figure out where everything should be and WHY. assuming they even know how to weld good.
This advice is why cars end up unfinished and built wrong.
Buying a proven front end like Bills for a street car ends up bunches cheaper in the long run and makes a persons car worth more on the resale. Not to mention can be raced in a lot of series where big tires and non stock front ends are not allowed.
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739640
02/01/15 01:44 AM
02/01/15 01:44 AM
USA
Low Deck Offline
Low Deck  Offline
USA
I have to agree with that. This is why I have done so much reading and research on proven setups even if it might be some time until I can buy one.
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739641
02/01/15 01:49 AM
02/01/15 01:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What he said!
going to the Duster from the Mirada I knew those dang torsion bars had to go.... and why not rid of that heavy steering box while I'm at at. Tube K, rack, coil overs..... A+ in all aspects!
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739642
02/01/15 02:49 AM
02/01/15 02:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Why do you think you have to jig struts... if you
dont know how to put them on.. fine have it done..
but I also understand not everyone wants them
Re: bigtimeauto / Alterkation users? [Re: MR_P_BODY] #1739643
02/01/15 07:00 AM
02/01/15 07:00 AM
Chesterfield Twp. Mi.
John Burdine Offline OP
the HDK has a bar or tube running across the back of the k for support, that's as bad as having a drag link when it comes to oil pans. I don't know why some pics of the HDK show this and others don't.
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739644
02/01/15 12:17 PM
02/01/15 12:17 PM
USA
Low Deck Offline
Low Deck  Offline
USA
I believe that it is an option. I'll email and ask them.
Re: bigtimeauto / Alterkation users? [Re: Low Deck] #1739645
02/01/15 12:22 PM
02/01/15 12:22 PM
USA
Low Deck Offline
Low Deck  Offline
USA
They said it was an option but not necessary.
Re: bigtimeauto / Alterkation users? [Re: Low Deck] #1739646
02/01/15 01:25 PM
02/01/15 01:25 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I know drag racing apps have very narrowly defined needs, but most suspension design rule of thumbs lean towards lengthening control arms, seldom ever shortening them increases positively any handling aspects. Additionally, it seems just whacking off a inch on the control arms of a designed proven system casually, with little no suspension recalculations, seems awful shade tree.
Re: bigtimeauto / Alterkation users? [Re: Gary Robbins] #1739647
02/01/15 04:09 PM
02/01/15 04:09 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Money shot !!
my money shot [image]http://[/image]
Re: bigtimeauto / Alterkation users? [Re: one bad fish] #1739648
02/01/15 04:20 PM
02/01/15 04:20 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
here is a picture when it didn't have 2500HP and with the junk qa1 shocks:
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739649
02/03/15 08:45 AM
02/03/15 08:45 AM
hey Bigtime, who's shocks are you running up front and what are the specs as far as extended/collapsed? what springs?
Re: bigtimeauto / Alterkation users? [Re: bigdad] #1739650
02/03/15 11:08 AM
02/03/15 11:08 AM
the house on the left.
cogen80 Offline
cogen80  Offline
anyone know if you can buy it without springs and shocks?
I tried to buy it less stuff, wasn't able to but, I didn't try really hard
It was complete with brakes, etc
$5350 shipped to me
Had I done a little more research, I'd bought one from Hemi Denny
same basic thing but, looks nicer
http://www.forabodiesonly.com/mopar/showthread.php?t=186472
And, I think its just a tad less $$ not much though
yes you can buy the alter-k piece by piece if you want.
as far as the hemi denny one goes at the end of the day if you use the same high quality parts as the alter-k uses its really no cheaper. and you have to spend the time to source all the parts. not a huge deal but for the same price i may as well one stop shop with the alter-k.
