Page 2 of 5 1 2 3 4 5
Re: bigtimeauto / Alterkation users? [Re: Thumperdart] #1739591
01/27/15 07:08 PM
01/27/15 07:08 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
First off the pic above is not rms stuff..42lbs brake,rack,k frame And hardware...maybe I'm off a lb Or Two.
I must say I do miss them 6 cylinder torsion bars though..:)
Re: bigtimeauto / Alterkation users? [Re: fishy340] #1739592
01/27/15 07:16 PM
01/27/15 07:16 PM
maryland
74yellowduster Offline
maryland
that kit is the hemidenny stuff
i have it on my duster. sits quite low.
here is a brake kit you can use on the various mustang ii kits that does not change the width.
ECI 704CK
http://www.ecihotrodbrakes.com/mustang_pinto_discbrake_conversions.html
this kit has aluminum hubs, granada rotors, heavy gm calipers, you could swap wildwood or ssbc lightweight calipers that are gm-sized
it keeps the track width stock, so you would not need wheels with special offset
We've done it! ECI has developed a Mustang II/ Pinto BIG BRAKE KIT that's perfect for your street rod. By combining components from existing kits, we can now offer 11" diameter rotors, BIG GM calipers and our aluminum hubs. This kit provides 65% more braking with no wheel offset! No other "Big Brake Kit" can offer this at any price!
Re: bigtimeauto / Alterkation users? [Re: bigdad] #1739593
01/27/15 07:39 PM
01/27/15 07:39 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
anyone know if you can buy it without springs and shocks?
I tried to buy it less stuff, wasn't able to but, I didn't try really hard
It was complete with brakes, etc
$5350 shipped to me
Had I done a little more research, I'd bought one from Hemi Denny
same basic thing but, looks nicer
http://www.forabodiesonly.com/mopar/showthread.php?t=186472
And, I think its just a tad less $$ not much though
looks like a copy of a alterkation? Is that mounts for a pinto rack and the shockes need to go to the stock shock brackets??
I think the alterkation is way less cluttered. I also like the mustang rack better.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: bigtimeauto / Alterkation users? [Re: fishy340] #1739594
01/27/15 11:21 PM
01/27/15 11:21 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have Alterktion on my Demon. Weight transfers just fine. I shortened the lower control arms 5/8". Car was only 45 pounds lighter when I installed the Alteration kit and switched front windshield from glass to Lexan. Car had a Wilwood lightweight brake kit with the stock suspension, and the Alterktion comes with a medium weight brake kit. No way you can lose 120 pounds. The whole stock K-frame with control arms, brakes and gear box does not weigh much more than 120 pounds. However the front tires last about 3 times longer with the Alterktion.
Re: bigtimeauto / Alterkation users? [Re: qwkmopardan] #1739595
01/27/15 11:46 PM
01/27/15 11:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I lost 42 lbs switching the front brakes alone.I'm not sure how you went From a stock front end to the rms and lost only 45lbs.
I'm not related to Bill the owner lol
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739596
01/28/15 01:37 AM
01/28/15 01:37 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I think if you call Bill and do some serious horse trading , he is more than receptive to working with you.
But consider that he must get a dozen calls a day from dreamers , whack jobs and [Edited by Moparts - Family Friendly Site - Keep it clean] compared to the couple people who are potential buyers.
We came to a couple mutually beneficial agreements and I also had some after purchase purchases......I found him to be very easy to work with.
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739597
01/28/15 01:54 AM
01/28/15 01:54 AM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
I bought mine for $4000 without shocks or springs but with the parts to install my Wilwood brakes. That was in June of 2013.
Re: bigtimeauto / Alterkation users? [Re: markz528] #1739598
01/28/15 04:38 AM
01/28/15 04:38 AM
sweden
sshemi Offline
sshemi  Offline
sweden
There is different brake kits to choose from with different track widths.
Although i think the lightweight drag kit is only avaliable as one offset witch increase the trackwidth compared to stock.
I have ordered the RMS suspension and i really hope its good.
Some seem to not like it but i cant see it being as bad as Magnum force.
If it is i will send it back...
Re: bigtimeauto / Alterkation users? [Re: sshemi] #1739599
01/28/15 04:51 AM
01/28/15 04:51 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
You can put a whole bunch of castor with the Alterkation, the car drives straight as an arrow and the front runners last a whole lot longer.
Re: bigtimeauto / Alterkation users? [Re: qwkmopardan] #1739600
01/28/15 05:11 AM
01/28/15 05:11 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
my friend has it front and rear...car drives and handles Killer!
Re: bigtimeauto / Alterkation users? [Re: John Burdine] #1739601
01/28/15 12:03 PM
01/28/15 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
John... why dont you go with Strange struts... WAY
CHEAPER and it includes everything you need (brakes
springs, lower A-arms.. everything except the rack...
its not hard to install at all... but I dont know if
you play in a class where you cant run the struts
$1900 gets it all
Re: bigtimeauto / Alterkation users? [Re: MR_P_BODY] #1739602
01/28/15 01:03 PM
01/28/15 01:03 PM
sweden
sshemi Offline
sshemi  Offline
sweden
$1900 gets it all
Totally agree!
If you CAN use struts thats the way to go.
Re: bigtimeauto / Alterkation users? [Re: MR_P_BODY] #1739603
01/28/15 02:46 PM
01/28/15 02:46 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
$1900 gets it all
what he saves in upfront money he will spend more on the install. that 1900 you throw out there does not include the rack, steering shaft and u joints or a jig needed to install the struts properly. A alterkation can be bought and bolted in with basic skills. CHEAPER hardly ever is better.
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739604
01/28/15 04:05 PM
01/28/15 04:05 PM
Chesterfield Twp. Mi.
John Burdine Offline OP
I guess the question I have is, can you get a strut/brake package that will be robust enough for some street use?
as bigtime said, alterkation is a bolt in, no fab needed.
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739605
01/28/15 07:49 PM
01/28/15 07:49 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Bob what advantage do you see between the mustang rack and the pinto rack?
Re: bigtimeauto / Alterkation users? [Re: SpareParts] #1739606
01/28/15 08:30 PM
01/28/15 08:30 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
street, it has less vibration and is sturdier.
race, none
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739607
01/28/15 11:33 PM
01/28/15 11:33 PM
jersey
Spaceman Spiff Offline
jersey
You guys have it easy with your removable K frames. Nothing out there for us old school full frame guys!
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: bigtimeauto / Alterkation users? [Re: bigtimeauto] #1739608
01/29/15 12:29 PM
01/29/15 12:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
$1900 gets it all
Yes it does take fab work... but if he has the front
bars going out then thats the bulk of it... you dont
need any jigs.. inclinemeter for the angles and a
welder.. I did say it didnt include the rack... he
has a column and it might need a splined rag joint..
they do make a heavier car system for the bigger
brakes(everything is a little beefier)
Re: bigtimeauto / Alterkation users? [Re: MR_P_BODY] #1739609
01/29/15 11:13 PM
01/29/15 11:13 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I looked at some pics of the alter k and it does appear to have short shocks on it...Question is, why did they not extend that reinforced mount for the top shock up higher some to get a longer shock in there? It seems there is plenty of room.
It also got my wondering about converting to coilovers without a rack or aftermarket k. Couldn't one fab up that same type of bracket, from some decent gauge steel, and create their own mount for a coilover shock that does not use the stock body mount? Obviously you are only gaining the loss of torsion bars and the switch to coilovers and nothing else, but I wonder if if could be done and work or if anyone has done it???
Re: bigtimeauto / Alterkation users? [Re: mshred] #1739610
01/30/15 12:06 AM
01/30/15 12:06 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Why make em longer ? Bigtime and a few others prove the system works..only upgrade is put a better coil over in.
