Re: Spark Plug
[Re: DusterKid]
#1739560
01/27/15 12:19 PM
01/27/15 12:19 PM
Thumperdart
State of confusion
So r u saying they really broke or are they wore out? If they actually broke from contact then that`s a whole nother deal.......
Re: Spark Plug
[Re: DusterKid]
#1739561
01/27/15 12:29 PM
01/27/15 12:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If they were burnt off thats one thing.. most times when they break off they break at the weld point .. tell us if they are burnt off... lets see a pic.. also if they were hit by the piston they would be bent down EDIT I run that same plug in my street/strip 416 with 10.4 compression.. also make sure you didnt put in the AR3924... thats the short ground strap for racing ![](/ubbthreads/images/graemlins/wave.gif)
Re: Spark Plug
[Re: MR_P_BODY]
#1739562
01/27/15 09:00 PM
01/27/15 09:00 PM
Posts: 1,776 Keymar, MD
DusterKid
Keymar, MD
I didn't see where they made contact with the piston to bend or brake. The 3 plugs picture were list this, the other 5 were normal. Since all the plugs had the same about of runs on them, if they were worn, wouldn't all of the plugs be about the same or no? Here are a few pictures. [image] ![](http://i164.photobucket.com/albums/u8/moparstud440/P1270014_zpsmerenxss.jpg) [/image] [image] ![](http://i164.photobucket.com/albums/u8/moparstud440/P1270015_zpso60q6swl.jpg) [/image]
Re: Spark Plug
[Re: Thumperdart]
#1739564
01/28/15 01:08 AM
01/28/15 01:08 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I use to run that plug when they were made in USA. When they started to be made in china or wherever, i will say around 2005, I quit buying them and started buying the AR plugs. I have never seen that happen and I have seen pistons hit plugs but it usually just bends the strap
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Spark Plug
[Re: DusterKid]
#1739566
01/28/15 01:03 PM
01/28/15 01:03 PM
MR_P_BODY
I see weld splatter on the one washer... but those ground straps look like the material is messed up.. they look like carbonized.. the grain structure looks really goofy.. I would say that it burnt off.. was it the same cyls that did it a second time ![](/ubbthreads/images/graemlins/wave.gif)
Re: Spark Plug
[Re: MR_P_BODY]
#1739567
01/28/15 01:21 PM
01/28/15 01:21 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Kinda off topic but why are you mixing race gas with that compression. Did you ever do a cranking compression test?
