Need help with 68 RoadRunner resto, please... #1738073
01/25/15 02:36 AM
01/25/15 02:36 AM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Putting my steering column back in and can'
t remember the orientation of the plate setup at the firewall. could someone post a few pics of theirs, please? 1inside and 1 out, please? thanks!
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Need help with 68 RoadRunner resto, please... [Re: 4boxers4] #1738074
01/25/15 12:49 PM
01/25/15 12:49 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I do not have any good pictures of the column installed. You should have two plates, a rubber gasket and a foam gasket. Between the next couple of pictures you should get the idea. Install small plate first, then rubber gasket, then large plate and finally the foam gasket. Leave all the hardware loose until the column is snug up under the dash and you have full engagement with the steering box coupler.
Re: Need help with 68 RoadRunner resto, please... [Re: 68jim] #1738075
01/25/15 12:52 PM
01/25/15 12:52 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Assembled
Re: Need help with 68 RoadRunner resto, please... [Re: 68jim] #1738076
01/25/15 12:57 PM
01/25/15 12:57 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Not sure if this one will help. The pictures were from my 68 RR project a few years ago.
Good Luck
Re: Need help with 68 RoadRunner resto, please... [Re: 68jim] #1738077
01/25/15 01:26 PM
01/25/15 01:26 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
'Awesome! thanks Jim!
Re: Need help with 68 RoadRunner resto, please... [Re: 4boxers4] #1738078
01/25/15 03:21 PM
01/25/15 03:21 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Center the steering shaft before you tighten the bolts.
