Re: Main studs or bolts
[Re: gss]
#1738057
01/27/15 12:28 PM
01/27/15 12:28 PM
Posts: 7,506 Az
Crizila
Az
Bottom line - If you are going to change hardware / torque specs, you should measure. Not that big of a deal.
Fastest 300
[Re: Crizila]
#1738059
01/27/15 12:59 PM
01/27/15 12:59 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I thought E'berg cleared this up eons ago. The stock bolt shank is smaller than the hole in the cap so it doesn't make contact with the bolt bore when it is torqued. An ARP stud is uniform diameter (larger) and on a lot of stock caps, will make contact. This is what causes the distortion on the main bores. In his article he opened up the bolt bores slightly so the studs had more clearance and the distortion vanished. My ? If you have the tools and the talent, install the caps with studs, torque them with the ARP lube and measure them. If the bores are still within the acceptable +/- .00000X, marvelous. If you find one that isn't that was OK with bolts, open up the bolt bores so the studs have clearance and it should then be marvelous too. Kevin
[Re: Twostick]
#1738060
01/27/15 02:37 PM
01/27/15 02:37 PM
Posts: 1,121 State, country, etc.
gss
Kevin
That is very interesting. Upon further inspection, there was NO align honing done at all with bolts or studs. I will be taking it to a different machine shop for align honing with the studs. Should I be concerned about the cylinders getting out of round?
[Re: Twostick]
#1738062
01/27/15 09:33 PM
01/27/15 09:33 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Kevin
Yep. I stated this Eons ago in this thread. my Caps had plenty of contact too with the new Wider shank studs. I redrilled my caps as well, but thsat wasn't enough. The higher torque value distorted them as well. Had to have the line hone, crank wouldn't spin without it.
So the Wider shanks of the studs and the higher torque value both play a roll with the altered tolerences.
[Re: roadhazard]
#1738063
01/29/15 07:01 PM
01/29/15 07:01 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I will also add, check your cylinder bores.
Really no reason to run studs IMO
When torque specs are changed everything distorts differently ...
unless you are a flat rate mechanic ...
[Re: dogdays]
#1738066
02/09/15 08:46 PM
02/09/15 08:46 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Something to be aware that happened with my 512 stroker with ARP studs and Road Race Pan.
Cinching down nuts on the oil pan studs at rear main retainer I felt the torque wrench suddenly loosen as though I had stripped either the nut or the stud that was screwed into the Mancini aluminum retainer.
Pulling the pan off, I found this. The number 5 rear main stud had barely caught the oil pan and what I had felt was the pan that had been caught, suddenly slid a bit as torque was applied thereby given me that quick release that I had felt.
Yes this main stud appeared to be properly bottomed in it block hole (I pulled it out to ensure nothing else was in the hole,,,all was well).
A bit of surgery with a Dremel rounded of a bit of the nut side of the stud and all is well.
To this day not certain if was a stud problem or Road Race pan issue. Only one gasket on pan,,,no windage,,, perhaps this had something to do with it,,,places pan closer to block,,,but doubt it.
[Re: Sxrxrnr]
#1738067
02/09/15 11:00 PM
02/09/15 11:00 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Some, not all , of ARP Mopar main stud kits come with two shorter studs in them, those two go in the back on # 5 main cap I make my own crankshaft scrapers that get glued to the block on the passenger and the half of one oil pan gasket gets glue onto the remaining oil pan surfaces and then go from there I use the scraper and stock windage trays with two more oil pan gaskets, lots of clearances between the block and oil pan with all that mess
[Re: Cab_Burge]
#1738070
02/25/15 11:30 PM
02/25/15 11:30 PM
Main thing to remember with studs since the studs are bigger and can be right up against the cap--it can screw up the thrust situation--the fix is the same --enlarge the hole in the cap--allowing you to move the center main cap enough to line up the thrust like you need to
[Re: gss]
#1738072
02/26/15 01:57 AM
02/26/15 01:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Final update. Got the block back from the machine shop. They checked everything and all is good. Even the mains didn't need align honing after installing the studs.
When you get to installing the crank and mains.. make sure you SET the end play.. with the mains just snug give the crank a whack back and forth with a dead blow type hammer to set the thrust bearing then torque it down
