MSD 6013 issue updated sad day
#1737752
01/24/15 05:05 PM
01/24/15 05:05 PM
Posts: 936 Deland, Florida
biff426
Deland, Florida
Well I went out to fire the car up today and it wont fire. Plugged the laptop in and it has a fault for all 8 coils. I changed the timing curve earlier in the week but never started the car WTF I unplugged the coils and I am getting 12v on the red wire at each coil anyone have any ideas?
Re: MSD 6013 issue
[Re: STEFF]
#1737755
01/26/15 07:37 PM
01/26/15 07:37 PM
Posts: 301 wisconsin
swifter
wisconsin
Mine is also turned off and I don't use the map sensor either-Steve
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
Re: MSD 6013 issue
[Re: swifter]
#1737756
01/26/15 08:27 PM
01/26/15 08:27 PM
dogdays
I don't own one. Having said that, I looked at the two harnesses online and it appears the only difference, beyond coil connectors, is the brown jumper on the 88864. So the 88863 is for a waste spark application, the 88864 is for non waste spark. I think it goes like this: On the 88864 because of the jumper, the system will not do the waste spark. If you ALSO turn off the waste spark in the computer, there should be no difference. But, on the 88863 harness there is no brown jumper and the system is set up for waste spark, because that was stock. If you wish to turn off the waste spark, you have to turn it off in the computer.
Make sense?
In general, when making modifications, when the item stops working, one undoes or redoes the last thing changed. What was the last thing you changed?
R.
Re: MSD 6013 issue
[Re: biff426]
#1737759
01/28/15 01:05 AM
01/28/15 01:05 AM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
I posted on your other post
For the 88864 - waste spark is set to 'off'
Did you also cut the brown wire 'loop' as you are sposed to?
I also posted a 'safe' tune.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: MSD 6013 issue
[Re: biff426]
#1737764
02/06/15 09:37 PM
02/06/15 09:37 PM
Moparmal
Well I finally got to the bottom of my no start turns out it was not an ignition issue the pin on the cam broke and allowed the cam to spin on the gear and..............bent every friggin intake valve so I have it apart and for the life of me I can't figure out how the pin broke it ran fine must have happened as I shut it off then of course cranking the crap out of it didn't help crazy thing is it didn't crank like it had no compression
Oh well...at least you weren't doing something dumb with the ECU..... You can at least feel good about yourself!
Re: MSD 6013 issue
[Re: Moparmal]
#1737765
02/06/15 11:17 PM
02/06/15 11:17 PM
biff426
Deland, Florida
Well still have not figured out why the cam pin broke I have checked all the following again 1.Piston to valve .160 on the intake 2.Coil bind .065 3.Retainer to guide .070 cam gear fit the cam perfect I have had about enough thinking about selling all this crap
