Removing powder coating ? #1737712
01/24/15 03:51 PM
01/24/15 03:51 PM
Queens, N. Y.
FASTBACK340 Offline OP
Queens, N. Y.
I have a pair of sheet metal valve covers that got scratched and I powder coated them. I want to strip off the powder coating and have the aluminum polished. What's the safest and easiest method to remove powder coat?
`68 Barracuda 340-S
Re: Removing powder coating ? [Re: FASTBACK340] #1737713
01/24/15 04:06 PM
01/24/15 04:06 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I have used paint stripper to remove powdercoating.
It works just like it does on paint, but if the powdercoat is really thick you might have to use a few coats of the stripper.
Paul
'69 Super Bee 383 EFI Turbo
Re: Removing powder coating ? [Re: Black_Bee] #1737714
01/24/15 04:27 PM
01/24/15 04:27 PM
IN
ahy Offline
ahy  Offline
IN
Re: Removing powder coating ? [Re: FASTBACK340] #1737715
01/24/15 04:30 PM
01/24/15 04:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
i'm almost positive there is a special powder coating stripper out there Contact one of your local commercial powder coating supplier to get it
Re: Removing powder coating ? [Re: FASTBACK340] #1737716
01/24/15 04:53 PM
01/24/15 04:53 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
eastwood (and probably a lot of other places) sells powder coat stripper. as mentioned, it's basically paint stripper.
Re: Removing powder coating ? [Re: FASTBACK340] #1737717
01/24/15 05:27 PM
01/24/15 05:27 PM
Chicago
PurpleBeeper Offline
Chicago
I'm a paint chemist & I used to sell powder coating. There are two ways to remove it. The easiest is to burn it off (powder coaters use "burn off" ovens if they make a mistake). You can also use a paint stripper as the other guys mentioned & the best ones contain methylene chloride which works great BUT is a known carcinogen and will also make you pass out if you don't have good ventilation... also a little rough on the skin. Soaking usually takes several days, even a week.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Removing powder coating ? [Re: PurpleBeeper] #1737718
01/24/15 06:17 PM
01/24/15 06:17 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
aircraft stripper - brush on and cover with plastic
Can also be removed by blasting - used to use plastic beads as not to damage the plating underneath (military parts).
Re: Removing powder coating ? [Re: SSAAHemiFan] #1737719
01/24/15 08:35 PM
01/24/15 08:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Permatex Gasket Remover is THE BEST to remove powder coat. It will peel off in minutes! And it will do NO harm to the aluminum. Comes in an easy-to-use spray bomb. Also won't burn your skin like paint strippers.
Blasting takes forever.
Powder coaters "burn" old coating off because its fast - for them - in a production environment.
Re: Removing powder coating ? [Re: Stanton] #1737720
01/24/15 09:51 PM
01/24/15 09:51 PM
Queens, N. Y.
Queens, N. Y.
Awesome responses guys, thanks!
I'll try the Permatex stuff first, then get more intense if that fails.
`68 Barracuda 340-S
