Another estimate et r5p7 #1736948
01/23/15 05:27 PM
01/23/15 05:27 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Roller cam take out motor.
Going in a -68 Dart with gforce 4 speed.
5.0 gears and 31" tires.
2.98 first ratio.
Slip clutch.
Really dont know what weight it will be at but pretty light.
Max 3000lbs.
Re: Another estimate et r5p7 [Re: sshemi] #1736949
01/23/15 06:56 PM
01/23/15 06:56 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Pic
Re: Another estimate et r5p7 [Re: sshemi] #1736950
01/23/15 06:57 PM
01/23/15 06:57 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
2
Re: Another estimate et r5p7 [Re: sshemi] #1736951
01/23/15 06:58 PM
01/23/15 06:58 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
3
Re: Another estimate et r5p7 [Re: sshemi] #1736952
01/23/15 07:00 PM
01/23/15 07:00 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Last
Re: Another estimate et r5p7 [Re: sshemi] #1736953
01/23/15 07:14 PM
01/23/15 07:14 PM
Finland
mafo Offline
mafo  Offline
Finland
my guesstimate, 9.25
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Another estimate et r5p7 [Re: mafo] #1736954
01/23/15 07:39 PM
01/23/15 07:39 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Ok. Think it will be aqhile before i get there...
4 link rear and this is my first so i have alot of learning to do.
Will have a Rms front suspension.
Gonna run it with what i have this year then maybe next year change camshaft and carb.
Not trying to set the world on fire but trying to build a fun to drive low maintenance car.
Re: Another estimate et r5p7 [Re: mafo] #1736955
01/23/15 11:06 PM
01/23/15 11:06 PM
In a house near you
Street Monkies Offline
In a house near you
haven't ran one of this combinations but I know a ton about most small block stuff. Getting the car to hook and go straight properly is half the battle. Once you get it dialed in it should run in the low 9s pretty easy. Nice dart and looks like a pretty decent build. Let us know how it turns out.
Re: Another estimate et r5p7 [Re: sshemi] #1736956
01/23/15 11:55 PM
01/23/15 11:55 PM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
I'd think it will run a very low 9 aswell. You need to get the weight out of the car. 3000 pounds is way to heavy for a car like that. I would be trying to save weight everywhere you can. Get the holesaw out and start drilling. And if it hooks hard on those 31's then start going down in tyre size and rear gear. You want the smallest tyre on the rear that still hooks. Less rotating mass. It's all about the weight with small cube engines.
Re: Another estimate et r5p7 [Re: OUTLAW565] #1736957
01/24/15 06:21 AM
01/24/15 06:21 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
When i bought the car it was driveable but then i cut everything out. Didnt like the way it was/looked.
Redid all but rear framerails and roof and most of the roll cage.
Re: Another estimate et r5p7 [Re: sshemi] #1736958
01/24/15 06:22 AM
01/24/15 06:22 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
The 3000lbs is just a number i through out.
Really dont think it will be that much.
Re: Another estimate et r5p7 [Re: sshemi] #1736959
01/24/15 10:12 AM
01/24/15 10:12 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
That is a great combo! Guess it will be fun running the 4-speed smashing through the gears at 9000 rpms.....
Re: Another estimate et r5p7 [Re: sshemi] #1736960
01/24/15 10:56 AM
01/24/15 10:56 AM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
Let us know how it goes man. I started another thread for everyone with R5 P7 engines to discuss what their doing and share pics and questions and stuff. Id like to hear about what everyone else is doing with these engines.
Re: Another estimate et r5p7 [Re: Oyvind Mopar] #1736961
01/24/15 01:42 PM
01/24/15 01:42 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Thats exactly why i bought the car.
And it WAS a pretty good deal.
But since i "had" to replace alot of parts and redoing most, the good deal is lost but i really dont care as i believe it will be a blast to drive it.
Re: Another estimate et r5p7 [Re: sshemi] #1736962
01/24/15 05:04 PM
01/24/15 05:04 PM
Norway (old world)
Norway (old world)
Great! Looking forward to see you at the Swedish Mopar nats at Orsa either this year or next!
Re: Another estimate et r5p7 [Re: Oyvind Mopar] #1736963
01/24/15 06:12 PM
01/24/15 06:12 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
I WILL be there this year....
