Cats whisker and seal adds too much friction #1736907
01/23/15 02:46 PM
01/23/15 02:46 PM
Niwot, CO Formerly denn...
dynorad Offline OP
dynorad  Offline OP
I just installed new cats whiskers and outer seals to my driver's door (67 GTX) and now the window is almost impossible to crank. Is there some sort of trimming treatment on the new parts needed to make the window work properly?
Re: Cats whisker and seal adds too much friction [Re: dynorad] #1736908
01/23/15 05:16 PM
01/23/15 05:16 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Not with the good ones, like Topcat or First Place. The older Year One style were like you described and just horrible to use.
Re: Cats whisker and seal adds too much friction [Re: 70440+6bbl] #1736909
01/23/15 06:22 PM
01/23/15 06:22 PM
dynorad Offline OP
dynorad  Offline OP
They are Top Cat, but purchased a couple years ago.
Re: Cats whisker and seal adds too much friction [Re: dynorad] #1736910
01/23/15 07:01 PM
01/23/15 07:01 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
I've used simple silicone spray to lubricate them, yes it streaks and leaves your window oily for a while but once you clean them a few times the rubber is 'treated' and has less friction
