65 B Body front sway bar
#1735855
01/21/15 07:56 PM
01/21/15 07:56 PM
Posts: 127 Missoula, Montana
ChadP
Missoula, Montana
Want to install front sway bar on a 65 Dodge Coronet 500 with big block. Car did not have factory sway bar. Any photos of sway bar installed on a 65 B-Body would be very helpful. Considering PST bar kit.
'65 Coronet 500
Re: 65 B Body front sway bar
[Re: 300_dup5]
#1735857
01/21/15 08:29 PM
01/21/15 08:29 PM
ChadP
Missoula, Montana
Stock K Frame - 1965 B-Body. Car was 361/auto, now 440/4 spd, but didn't change K-frame.
'65 Coronet 500
[Re: Cab_Burge]
#1735861
01/23/15 01:07 PM
01/23/15 01:07 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
I never seen a stock 1962 to 1965 B body have a sway bar from the factory,6 cyl, SB or BB Thats based on owning 6+ of them
They were generally on wagons, cop caps, and hi-po big-blocks. Friend's '62 Polara 500 had one.
Rick
[Re: Rick_Ehrenberg]
#1735862
01/23/15 01:25 PM
01/23/15 01:25 PM
ChadP
Missoula, Montana
Thanks Rick - the bar I ordered from PST has not arrived yet...will be interesting to see if it's designed like the examples you sent. Appreciate the diagram and photo.
'65 Coronet 500
[Re: AndyF]
#1735864
01/24/15 02:55 PM
01/24/15 02:55 PM
Posts: 1,954 Illinois
SGTFURY62
Illinois
I've used a 69 one in a few of my cars (62-65). Just drilled the mounting holes in k member lip for mid bar mounts and used hellwig control arm mounts. Worked wonderfully and on the cheap.
[Re: Cab_Burge]
#1735866
01/25/15 12:33 AM
01/25/15 12:33 AM
Posts: 391 kansas
farmboy
kansas
This 64 had a sway bar, and the big front brakes, only one I have ever seen.
