'60s axle bumpers similar? #1735680
01/21/15 03:58 PM
01/21/15 03:58 PM
Chino Valley
RodStRace Offline OP
Chino Valley
I'm back on my 1966 A-100 and need to source the bumpers located above the axles front and rear.
Are these shared with other models and are they available?
I can supply pics and measurements tomorrow if needed.
EDIT: Removed the huge picture, I'm looking for the rubber parts that go above the axle, on the body, not the snubber.
They are similar to these Chevelle parts.
Re: '60s axle bumpers similar? [Re: RodStRace] #1735681
01/21/15 07:48 PM
01/21/15 07:48 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Looks to me like the rubber you are referring to is the pinion snubber. It looks to be the same as what was used on all the cars through the 60s & 70s. I would think a replacement rubber should be available, Mopar made adjustable snubbers (rubbers with the brackets) for racing purposes. Gene
