Mike, yes a ton of time and work into both. The Duster has a 512 fr0m Scotty Brown coming but it has got, new tires, rims, brakes, dist, coil, batter, water pump, fan, carb and master cyl. Body wise, new 1/4s both sides, hood and paint. I will be re-wiring it when I put the new motor into it.
Yes I am still in AZ. thinking 2 more years. then back to Michigan, but things can change....
a couple more of the Duster coming.
pics are too big. will post as i can.
