Set of 59* W9s I am finishing up #1733709
01/19/15 01:19 AM
01/19/15 01:19 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
303cc intake port for you 59* guys.
Going on a 472
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733710
01/19/15 01:28 AM
01/19/15 01:28 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Work of art.
care to share flow #'s ?
Re: Set of 59* W9s I am finishing up [Re: tubtar] #1733711
01/19/15 01:32 AM
01/19/15 01:32 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Work of art.
Normal deal is 380s-390s
260s-270son exhaust side
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733712
01/19/15 01:38 AM
01/19/15 01:38 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
How good or bad is the air speed with that much port volume Brett?
Thanks for the pics.
Re: Set of 59* W9s I am finishing up [Re: Darryls-Demon] #1733713
01/19/15 01:48 AM
01/19/15 01:48 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Air speed is still fast this port was on the 2011 engine masters 411ci 535 of TQ at3500 rpm.
In the big picture the port is still small 3" at port opening
Over 320feetper second down center of port
380-425FPS over short turn.
You can have large lazy port or larg port that is designed properly that for the most part has a much more Homogeneous flow floor to roof
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733714
01/19/15 12:41 PM
01/19/15 12:41 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
you like those victory valves better than the ferrea 6000?
Re: Set of 59* W9s I am finishing up [Re: mopar dave] #1733715
01/19/15 01:00 PM
01/19/15 01:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Ferrea 6000s aren't titanium...
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733716
01/19/15 01:03 PM
01/19/15 01:03 PM
BradH Offline
BradH  Offline
I suspect the SpeedTalk gurus would say the fps #s over the SSR are too high, since they seem to claim 350 as the max during multiple threads I've read "over there."
Me? I just grind 'em and run 'em!
Well, not exactly.
Re: Set of 59* W9s I am finishing up [Re: BradH] #1733717
01/19/15 01:48 PM
01/19/15 01:48 PM
MD
ADakotaRTGuy Offline
MD
Nice work, motivation to pull the engine today.
Re: Set of 59* W9s I am finishing up [Re: ADakotaRTGuy] #1733718
01/19/15 02:16 PM
01/19/15 02:16 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thanks Brett for the head porn,now you have my attention,curious question,, what was the final chamber size on those beauties.
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733719
01/19/15 02:20 PM
01/19/15 02:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Brett... I see some welding on them... whats with that
or is it where you went through... some spots dont
even look near the ports.... but they look great
Re: Set of 59* W9s I am finishing up [Re: MR_P_BODY] #1733720
01/19/15 03:01 PM
01/19/15 03:01 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That's pushrod pinch area, Mopar designed them to run a 550 offset rocker and Brett makes them take a 750 rocker for his port program.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Set of 59* W9s I am finishing up [Re: 1967dartgt] #1733721
01/19/15 03:05 PM
01/19/15 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733722
01/19/15 05:10 PM
01/19/15 05:10 PM
In a house near you
Street Monkies Offline
In a house near you
I always like to hear this big lazy port vs a big well designed port kind of discussion. What makes the port to big or even to small? Depending on if we are basing this off for every engine or a particular combination. Big port on small cubes is going to need a lot of rpm to make port efficient. It might never become efficient if you can't spin it high enough. A big ci motor is different. More ci will move more air at a lower rpm vs a small ci. But it also depends on how many rpms, both engine sizes, and rpm. Rpm is cubic inches also.
Re: Set of 59* W9s I am finishing up [Re: Street Monkies] #1733723
01/19/15 05:43 PM
01/19/15 05:43 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
How about you go check mis cross section and valve size on 360 LS3 chevy then get back to me on the large port not working on small CI or need big RPM to make it work.
A properly designed larger port for giver CI will work better than the BS high velocity small port.
And as I said this is only 3" min CS not large by todays standards.
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733724
01/19/15 07:03 PM
01/19/15 07:03 PM
australia
charger410 Offline
charger410  Offline
australia
Nice job your right 300cc cross section ain't big especially for that 472ci. I've got a set of SBC heads that have a 338cc port on a 510ci motor. Thanks for posting
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: Set of 59* W9s I am finishing up [Re: W5DART66] #1733725
01/19/15 07:12 PM
01/19/15 07:12 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Brett knows as he's had his hands on enough high performance heads but its a lot off work and know how managing and controlling air-speed in MOST of the heads out there. Even something like the set of B1 heads I am doing for my car are hard getting the short-side slowed down. But if you take the time the pay-offs are there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Set of 59* W9s I am finishing up [Re: pittsburghracer] #1733726
01/19/15 08:04 PM
01/19/15 08:04 PM
ohio
all spooled up Offline
ohio
bretts all motor small block dart is only in the 8s
Re: Set of 59* W9s I am finishing up [Re: pittsburghracer] #1733727
01/19/15 09:08 PM
01/19/15 09:08 PM
In a house near you
In a house near you
I was just funning him. Surprised I didn't catch more crap then that lol.
Re: Set of 59* W9s I am finishing up [Re: Street Monkies] #1733728
01/20/15 01:45 AM
01/20/15 01:45 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Sarcasim (SP?) gets lost very quickly on the net and when it is written word rather than spoken word. The board here, like any internet board starts to become a tight nit group. Swords are draw first, questions after your diced.
Hey Brett! I sure wish they made a lot of those heads. Actually, i still wish they made them. Not that I could make use of them .... yet....
