quench Q's #173316
12/23/08 12:10 PM
12/23/08 12:10 PM
RapidRobert Offline OP
BB w 915 closed chamber heads. The dished pistons I have in mind have the perfect deck height which would give me good quench (.035") but the problem is that the diameter of the perimeter around the dish is .445" wide as opposed to a much larger quench area on a legitimate set of quench pad pistons. I can get these very cheap but if this will not be enough FLAT AREA to give me effective quench even though the piston to head distance is correct(.035") then I need to move on. What do you guys think? Thank you for your time.
Re: quench Q's [Re: RapidRobert] #173317
12/23/08 01:26 PM
12/23/08 01:26 PM
Get-X Offline
Get-X  Offline
I too am looking for a good set of shelf pistons that optimize quench with 915s. Just a pump gas street motor with a moderate hyd. cam. Trying to run as much compression with pump gas and iron closed chamber heads as possible.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: quench Q's [Re: RapidRobert] #173318
12/23/08 01:40 PM
12/23/08 01:40 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You want a reverse dome piston. Only the area under the combustion chamber should be dished. the other side should be flat with no dish to maintain quench. Keep looking, they're out there.
Re: quench Q's [Re: Get-X] #173319
12/23/08 01:42 PM
12/23/08 01:42 PM
with good quench we could run a CR in the mid 10's on pump gas, no way that high without it. This fantasy buildup is a 440 block, 4.250" 440 source crank, 7.1" chevy rods & some eGay 403 olds cast pistons for just over $100. Problem is the non machined ring around the dish is only .445 wide but with a CH of 1.595, bore of 4.351"(std) it'd work ex for the not enough quench area. Might have to just spend the extra & get it right.
Re: quench Q's [Re: RapidRobert] #173320
12/23/08 01:47 PM
12/23/08 01:47 PM
GomangoCuda Offline
GomangoCuda  Offline
What are you going to do about valve notches?
Should look like this. Also called a D shaped dish. Unfortunately they are going to cost hundreds more than those Olds cast pistons.
Re: quench Q's [Re: RapidRobert] #173321
12/23/08 03:11 PM
12/23/08 03:11 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Why would you use the olds piston when Brandon sells the dished quench piston for that combo?? With 84cc heads & the 17cc dish pistone, deck height set at 10.720 & a .039 gasket you get 10.35 C/R...Why fight it?
Edit recalculated with 81cc head (typical 915) & 10.725 deck height (.044 quench) 10.51 C/R
Re: quench Q's [Re: 1_WILD_RT] #173322
12/23/08 03:43 PM
12/23/08 03:43 PM
alright you guys' expertise has persuaded me to do the right thing here, that & I just think I'd be uncomfortable with a GM part in there, heck I had a hard enough time using an aftermarket HEI module & only then because it was given to me. Thanks guys for taking your valuable time to guide me with this.
Re: quench Q's [Re: RapidRobert] #173323
12/23/08 03:45 PM
12/23/08 03:45 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your worried about a GM part ya better lose the 7.1 rod & the .990 pin..
Re: quench Q's [Re: 1_WILD_RT] #173324
12/23/08 03:47 PM
12/23/08 03:47 PM
I forgot about that
Re: quench Q's [Re: RapidRobert] #173325
12/23/08 03:50 PM
12/23/08 03:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I forgot about that
I think it will be ok...Just don't tell anybody///
Re: quench Q's [Re: 1_WILD_RT] #173326
12/23/08 03:54 PM
12/23/08 03:54 PM
I used one of those custom brackets that tucks the hei up under the dist, was a noticeable improvement making the ecu/ballast/& wiring dissappear.
Re: quench Q's [Re: RapidRobert] #173327
12/23/08 04:00 PM
12/23/08 04:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Back around 97-98 I put a Holley Projection unit on my Challenger, As part of the conversion to use the built in timing with knock sensor it needed a GM ingnition so I locked out a Chrysler electronic & fed the output to a HEI module...The ignition was about the only thing on that whole conversion that was trouble free..I fought that POS for about a year till I went back to a nice reliable carb.... Ford, Chevy whatever as long as it works better I use it...
Re: quench Q's [Re: 1_WILD_RT] #173328
12/23/08 04:25 PM
12/23/08 04:25 PM
I'm starting to get that way just a slight bit myself, not much though I'm still pretty much diehard Mopar & I for sure wouldn't be braggin about my olds pistons if I went that way which I dont think I will be now but I did really like that HEI being tucked up in there. I remember when Holley came out with those projection setups. When you got it right was it good?
Re: quench Q's [Re: RapidRobert] #173329
12/23/08 04:33 PM
12/23/08 04:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW I worked as a electronic engine controls specialist for a Ford L/M dealer for years, so I have a pretty good background with electronics..Here's the story that I posted about it a few years back...
I ran a Holley Pro jection DFI system, it ran great....Sometimes...It had no memory capabilities, so the only way to find a problem was to be watching the laptop when it screwed up...If it were a hard fault, no problem, but intermittent problems weren't so easy...The first time I fired it up it had a failed injector...replaced TB assy under warranty...Next a intermittent air charge sensor, it was quicker to just buy one, only $50.00, running pretty good, took a road trip to LA, lost a MAP sensor about 15 miles from home, luckily it made the other 600 or so miles...Running good again, drove it most of the summer, not as consistent as the carter carb but way cooler to be able to pop the hood & say "Yeah its Injected"... Another road trip, Sacramento, on the way there I start getting a surge, about 40 miles from home the surge starts feeling worse, I pull off the freeway & the car dies...Call AAA & tow it home...Lost a fuel pump, leaned out & cracked a manifold...As it turns out the exhaust wound up fighting me for three years after that till I got both the warpt flanges & the other manifold replaced as well...You know the carter runs really consistent I think FI is a good thing, I just feel Holley did a cheap half-a$$ job of it & used the cheapest components that the bean-counter in charge of purchasing could find...
I think that covers it...
Re: quench Q's [Re: 1_WILD_RT] #173330
12/23/08 04:53 PM
12/23/08 04:53 PM
boscosis Offline
super street
boscosis  Offline
super street
I installed a 900 CFM Holley Pro-Jection back in 1993. This was no small amount of money for me at the time ($950) and still wouldn't be. It worked OK and I liked and drove the truck with it for about 2 years. When I acquired a different truck I parked the one with the Holley Pro-Jection and only started it up every once in a while. About a year after that the CPU died and would no longer fire the injectors. I talked to Holley and they said the unit was disposable and could not be rebuilt. The only thing thing that they could do was sell me a new CPU for $400.
Needless to say I removed it and installed a carb. After that I would never purchase any Holley FI equipment and I try very hard to not purchase from Holley or any subsidiaries, but as you can imagine sometimes that's difficult with as many companies as they own.
To be fair, my brother has been running the same system trouble free for about 11 years, but I don't want any part of it.
