Restricting cam oiling on street engine? #1732355
01/17/15 07:41 PM
01/17/15 07:41 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Is it OK to drill a smaller hole in the cam bearing and line that one up intead of the big factory hole in order to get a little more to the crank? If yes how small to go?
Re: Restricting cam oiling on street engine? [Re: HotRodDave] #1732356
01/18/15 01:32 AM
01/18/15 01:32 AM
I never seen a need for that, even on all out roller cam race motors oiling the rockers full time through the # 4 cam journal Your choice, your call
Re: Restricting cam oiling on street engine? [Re: Cab_Burge] #1732357
01/18/15 02:05 AM
01/18/15 02:05 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I have ran .063 holes in the cam bearings with no problem, but I was not oiling the rockers though the block
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Restricting cam oiling on street engine? [Re: dusturbd340W5] #1732358
01/18/15 02:12 AM
01/18/15 02:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What were you oiling then with that hole
Re: Restricting cam oiling on street engine? [Re: MR_P_BODY] #1732359
01/18/15 08:12 PM
01/18/15 08:12 PM
Kalispell Mt.
Kalispell Mt.
Should have clarified it is a magnum so PR oiling. Just the bearing journal it self is going to get oil from that hole, nothing else.
Re: Restricting cam oiling on street engine? [Re: HotRodDave] #1732360
01/19/15 01:19 AM
01/19/15 01:19 AM
so ca
mikesiron Offline
mikesiron  Offline
so ca
In my round track engines I tape the oil hole from the main bearing to the cam bearings 5/16-18 and put an allen set screw in the center three mains. I drill the set screws with a .090 drill.
Re: Restricting cam oiling on street engine? [Re: mikesiron] #1732361
01/19/15 02:14 AM
01/19/15 02:14 AM
408Dust Offline
408Dust  Offline
.030 on mine no need for all of that oil to the cam bearings. PR also.
Re: Restricting cam oiling on street engine? [Re: 408Dust] #1732362
01/19/15 03:28 AM
01/19/15 03:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How many rpms are you guys turning that you have to
restrict the oil to the top... did you spin any main
or rod bearings before... I run LA stuff and never
reduced the volume to the top and I never drained the
pan(over size pan) and dont have a problem spinning
bearings .. turning up to and higher than 8200 rpm
Re: Restricting cam oiling on street engine? [Re: HotRodDave] #1732363
01/19/15 03:35 AM
01/19/15 03:35 AM
1/16" hole in set screws for all (5) cam journals. It's worthwhile as alot of oil is wasted down there. go to www.moparchat.com then scroll down to & click on "circle track chat" then read thru Sanborns oiling mods that are in a sticky at the top (it'll take ya awhile) for the whole scoop
Re: Restricting cam oiling on street engine? [Re: MR_P_BODY] #1732364
01/19/15 05:42 AM
01/19/15 05:42 AM
408Dust Offline
408Dust  Offline
8300 to 8500 no bearing problems super stock motor.
Re: Restricting cam oiling on street engine? [Re: 408Dust] #1732365
01/19/15 05:39 PM
01/19/15 05:39 PM
Kalispell Mt.
Kalispell Mt.
More of a longevity/high miles, thing heavy load on the motor pretty much all the time. I have seen plenty of high miles stock engines spin crank bearings. I figure a tad more oil kept in the pan and a tad more to the crank bearings would help if it is not needed at the cam journal.
