#1095 Tail Light Bulbs #173162
12/22/08 10:51 PM
12/22/08 10:51 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
For a 1970 Charger The factory manual calls for #1095 Light Bulbs...WHERE CAN I FIND SOME?
CHECK OUT MY NEW WEB SITE !
Re: #1095 Tail Light Bulbs [Re: anlauto] #173163
12/22/08 11:27 PM
12/22/08 11:27 PM
allan
Re: #1095 Tail Light Bulbs [Re: anlauto] #173164
12/22/08 11:29 PM
12/22/08 11:29 PM
Upstate NY
Big_John Offline
Big_John  Offline
Upstate NY
Re: #1095 Tail Light Bulbs #173165
12/23/08 12:07 AM
12/23/08 12:07 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
allan
Tom... you crack me up..... You have everything !!
Troy
Troy
Houston Mopar Connection Club
Re: #1095 Tail Light Bulbs [Re: anlauto] #173166
12/23/08 10:19 AM
12/23/08 10:19 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Word of warning, be sure they are brass based just like the GEs pictured. There are a lot of alluminum finished bases out (mostly imported) there that corrode, ruining the socket they sit in and offering intermittent operation.
Craig
Re: #1095 Tail Light Bulbs [Re: denfireguy] #173167
12/23/08 10:26 AM
12/23/08 10:26 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
You can also substitute the 1095 with either of the following...
#67 MINIATURE BULB BA15S BASE - 13.5 Volt .59 Amp
#89 MINIATURE BULB BA15S BASE - 13.0 Volt .58 Amp
#97 MINIATURE BULB BA15S BASE - 13.5 Volt .69 Amp
#1095 MINIATURE BULB BA15S BASE 14 Volts .51 amp
I run the #67's myself...
1MYTGTX
