Page 2 of 4 1 2 3 4
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: VincentVega] #1731243
01/16/15 09:19 PM
01/16/15 09:19 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
So what is the point of the discussion? to talk theory, or application?
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: JohnRR] #1731244
01/16/15 09:25 PM
01/16/15 09:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
6pak discussions on moparts are amusing,...sometimes.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: DaytonaTurbo] #1731245
01/16/15 09:27 PM
01/16/15 09:27 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
How is it that nobody makes a good single plane 6 pack intake?
Try a Weiand S/S intake, tunnel ram-single plane type. End carbs are like the size of a 800 dp and i guess the middle should be close to a 600. So 800 + 300 = 1100 would be more likely, unless those four barrels don't flow what they advertize either. I would say six barrels should flow a lot more than any four barrel except the dominator. Good test for you flow bench guys, just flow half of a four barrel, say an 850 then the six pac two barrel at the same rate to clear the air.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: VincentVega] #1731246
01/16/15 09:33 PM
01/16/15 09:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
On a large enough engine, with a big enough draw, who is to say it won't pull 3 inches? or even more? If it does that, then the 1350 capacity is now reality. I would say on a big enough engine, with cam, and high rpm, it should be possible.
It doesn't work that way.
The carbs are rated for flow using specific pressure differences across the throttle. A high vacuum below the throttle will draw more air.
The 2 bbl got its rating with a higher draw. That means you can't compare the numbers directly with a 4bbl.
If tested like a 2 bbl, a 750 CFL carb would get a 1050 rating.
- Stu Harmon
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: VincentVega] #1731247
01/16/15 09:52 PM
01/16/15 09:52 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
If you are pulling 3 inches at WOT, your carb is too small and it is costing you power.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: forphorty] #1731248
01/16/15 11:55 PM
01/16/15 11:55 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
How about three of these split Dominator carbs
http://www.chucknuytten.com/carburetors/Split%20Dominators/splits.html
Gus
64 Plymouth Savoy
Dana 60
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: JohnRR] #1731249
01/17/15 12:16 AM
01/17/15 12:16 AM
AndyF Offline
AndyF  Offline
Understanding the 6 pack CFM is one of the hardest things for Mopar guys. A really big percentage of them will never figure out the whole 2bbl flow rating thing. I gave up correcting people a few years back but I'm glad to see that you're still putting up the good fight!
The equiv flow rating of 900+ cfm is enough to make really good power, it is the twists and turns inside of the stock intake that kills the combo. Especially at high rpm and/or lots of cubic inches. But the setup can easily make 600 hp on a healthy short block so it does work really well up to a point. And that point is more power than what 99% of the folks need on a street car anyway.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: AndyF] #1731250
01/17/15 01:09 AM
01/17/15 01:09 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Here is an easy way to TRY and explain it. I am building a hot street 440 with a six pack. The carbs are here now.
The venturi and butterfly measurements of the two 500 cfm two barrels carburetors is exactly the same as the customers current 850 four barrels.
So whatever the 350 carburetor would flow compared to a four barrels is the only gain.
I will make a post later about the intake, porting, etc
Keith
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: Dunnuck Racing] #1731251
01/17/15 01:33 AM
01/17/15 01:33 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Keith
But isn't the 850dp slabbed throttle shaft with thin throttle blades? And original 6 pack carbs full shafts with thicker throttle plates sandwiched in the middle?
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: AndyF] #1731252
01/17/15 10:18 AM
01/17/15 10:18 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
These comments bundle it up pretty nicely. My limited testing show that a stock 6bbl intake starts to give way to other manifolds above 550 peak hp, and average power not much after that. I'm not suggestion that I won't go 650 hp.
I'm really surprised that carb manufactures have not started to give air flow curves at multiple pressure drops, say from .4" to 2.0" Hg., not that guys like me lower on the food chain would need to know anything much above 1.0" Hg.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: BSB67] #1731253
01/17/15 11:02 AM
01/17/15 11:02 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
`68 Barracuda 340-S
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: FASTBACK340] #1731254
01/17/15 12:50 PM
01/17/15 12:50 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 6pak/6bbl needs to be thought of as a vacuum secondary 4bbl with 2bbls added. those carbs should never be thought of as three independent carbs; which is the way holley currently rates the air flow. 1350cfm is a bogus marketing ploy. if i remember correctly the original flow rating was 1030cfm. cfm ratings have become a manipulated marketing ploy. i don't know why people take them seriously.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: AndyF] #1731255
01/17/15 03:37 PM
01/17/15 03:37 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Well said.
Another way of looking at it is this;
- at the 450 - 500hp level the stock six pack setup is one of the best setups available and makes more average power and torque than all but a couple of the best aftermarket intakes and 4bbls. It's far superior to the factory 4bbl manifold and carb yet people always want to compare the stock 6 pack set up to and aftermarket 4bbl.
- After that level, you are giving something up to run the 6 pack but that doesn't mean you can't make 650 or 700 hp with one as evidenced in this thread. It's kinda like headers; at this HP level, you'd be able to make more power with a good 4bbl intake and carb but it depends on how you view it: do you want max power for your particular engine or do you want to make your target hp (whatever that is) using a 6 pack.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: lewtot184] #1731256
01/17/15 06:46 PM
01/17/15 06:46 PM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
this 493 was 595hp and 650ftlbs with a shop 950 and Performer RPM. I'm going to run the sixpack because I already have the intake and carbs
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: Mr.Yuck] #1731257
01/18/15 04:06 AM
01/18/15 04:06 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I'd think with some clean up work and a good tune on the carbs he'll be fine. I wouldn't just drop a out of the box unit on and think it will be fine. There are some tricks you can do w/ the outboards that make them run better or he can bite the bullet and get the outboard metering plates. I don't have near the build but I do enjoy getting 15mpg and running mid 11's (low 11's soon)
I have the ProMax metering plate in my center carb
and the jet-able metering plates for the end carbs
I also have the splayed-idle screw base plate for the rear carb
All I know is it pulls like a freight train and drives great. I have a mild cam, 10:0-1, Edlebrock RPM heads, MSD ignition, and TTI exhaust. 4 spd and 4:10 gears.
Fun doesn't begin to describe it
`68 Barracuda 340-S
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: cudaman1969] #1731258
01/18/15 05:34 PM
01/18/15 05:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know a guy who runs the Mod Man six pack setup on an Indy headed 440 stroker in a 69 Bee. I have seen him run 10.50's but I really dont know alot about his eng build other then it has Indy parts. I wonder how the Mod Man 6 pk compares up to the stock intake ? Ron
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 4spdana] #1731259
01/18/15 06:52 PM
01/18/15 06:52 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Member Dennis Grossman (aka 6bblflash) has his big block Six Pack 'Cuda running 9.80's.
I believe he's using what started as a stock aluminum dual plane Six Pack intake that he modified.
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 70BigBlockSE] #1731260
01/31/15 09:27 PM
01/31/15 09:27 PM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
That is a thing of beauty. I would love to see a dyno comparison of the Weiand you have with the carbs to the Performer RPM. Not entirely Apples to Apples for me, I have a little 446ci engine. Is the intake modified? I hear they have idle fuel mixture issue. I think I have a way around that problem.
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 68cuda440] #1731261
01/31/15 11:45 PM
01/31/15 11:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know I have seen a few 440 dyno runs on engines making about 60 hp where the six pack was within 10 hp of the single plane and a 950 carb. On a street car the 6 pk will work pretty good if setup right as I would run one if I had a car that could have had the 6 pk option. I run this Indy dual plane intake with just an 850 DP on my 493 and I am very happy with it. With the dual plane and the DP carb it has great driveability and any rpm. I can hit it driving on the street in any gear at any rpm and it goes. Sure it may be a tad faster at the track with a single plane but this setup got me in the 10's that I was shooting for and has such good driveability that on my street car it may be giving up a tenth or so at the track but I have no complaints with the dual plane. Ron
Re: Maxium Power Through 6-Pack Induction w/500 inches [Re: 383man] #1731262
02/01/15 12:01 AM
02/01/15 12:01 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I usually think of it this way; if the build would be a good fit for a performer rpm it'd be good for the 6 pack. The Eddy 6 pack intake works/worked really well for something designed in 1969.
A buddy has a stock stroke 440 with a 260 @ .050 cam, Super Comps, Indy SRs, etc. 601 horse on the dyno with the 6 pack. He was worried about the engine when he bought the car but it has been reliable as can be. I'd like to see what it'd do with a Victor and an 850 on it.
Page 2 of 4 1 2 3 4
