Re: The great oil pan gasket question for big block mopar
[Re: bee1971]
#2034062
03/18/16 08:11 PM
03/18/16 08:11 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
When ordering #2585 is that for a pair or one gasket ? They are packaged 1 gasket per package. You need 2 with a windage tray
Also do they sell a rear main seal ? Yes, Part #9383 includes 2 crank seal halves and 2 retainer side seals and instructions.
And some say to put #2585 on dry , while road hazard says put a bead of silicone on the oil pan rail ? Instructions are included but in short, 1/8" "bead" of Permaex Ultra Black on the pan rail of stamped steel pans, noting usually required for fabricated pans with rigid rails, nothing on the block sides, nothing between the windage tray and gaskets either. Maybe a thin bead across the stock seal retainer.
Bought a new reproduction stamped 402 oil pan and windage tray , want to do it right while motor sits in car I have the same pan on my Charger Test Mule. Be sure to check flatness of the timing cover to block rails.
Thanx Scott Hope this helps you out Greg
[Re: GY3]
#2034073
03/18/16 08:25 PM
03/18/16 08:25 PM
roadhazard
Akron, Ohio U.S.A.
I notice that after a couple of heat cycles on a new engeine, the pan bolts tend to loosen and need to be retorqued.
That is the result of a soft gasket used to compensate for very irregular surfaces and is generally inexpensive. It will not retain bolt torque. Also tends to "wick" oil through the gasket causing external dampness that dust and dirt likes to cling to. Put the #2585 pan gasket on my Charger Mule about 5 years ago. Bolts are still tight and no weeping through the gasket.
[Re: 1964superstock]
#2034107
03/18/16 09:28 PM
03/18/16 09:28 PM
Posts: 2,822 Sobieski Wi
bee1971
Sobieski Wi
Thanx Greg
All Questions Answered
Peace
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
#2100972
06/30/16 06:35 AM
06/30/16 06:35 AM
bee1971
Sobieski Wi
Everything is apart , cleaned up and ready to install
Bought the billet rear main seal retainer kit from Mancini racing
Should I use the supplied rear main seal from Mancini racing or I also bought the Superformance rear main seal when I purchased there oil pan gaskets , thinking of using there rear main seal with the Mancini billet retainer
Then obviously using the double side black rubber o rings supplied with Mancini kit
Anyways , any other tricks used installing this Mancini racing billet retainer before I button everything up today
Superformance rear main seal work with the Mancini racing billet retainer ?
[Re: 451Mopar]
#2101305
06/30/16 07:24 PM
06/30/16 07:24 PM
bee1971
Sobieski Wi
Use the superperformance rear main seal, offset about 1/8" from the parting line.
I use the ultra gray between the block and girdle.
Sounds like the superperormance pan gaskets are the way to go. I used the Fel-pros with steel core, but not really impressed with them. I have the Jegs windage tray/gasket on a different engine and it sealed up great.
I think the girdle kit uses studs and has the bolts with serrated surface to hold the pan on? My girdle kit was the older one from BCR.
Anyhow, a bit of blue loc-tite will help the oil pan bolts / nuts from loosening. Thanx Many have reported that the Jegs wind age tray rubber o ring oil pan gasket will not work with the factory 402 oil pan , or any factory oil pan for that matter because the mating surface on the factory pans is not completely smooth flat , factory pans have those recessed areas
#2101537
07/01/16 12:26 AM
07/01/16 12:26 AM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
One picture says a thousand words,,,,,,,,
#2102868
07/03/16 08:22 AM
07/03/16 08:22 AM
bee1971
Sobieski Wi
Rear main seal leaks 100 times worse now then the one it replaced
New 402 oil pan and superformance gaskets are awesome
Put black rtv on the ends where it contacts the block , side o rings go into holes in the retainer on the ends then swing around the sides
Used the superformance rear main seal ,seal lip on both halves facing inward towards the crank
Only thing I didn't do was silicone the sides of billet retainer because I thought that was the purpose of the double o rings , you know to keep oil from leaking by the o rings
But after some more research ???
Anyways I am beyond pissed
Any better o ring material for those side seals that I can pick up locally ??? They fit in the tiny holes on the end of retainer nicely to hold in place , but coming down the sides you have to keep them in place in the grooves while sliding down the retainer inward on the block , wish the rubber was a little wider
Black rtv or Copper on the sides of retainer , yes or no ???
Should I offset the rear seal more then a 1/8" so it's not flush with the parting line of block
Also the superformance rear main seal versus the Mancini rear seal supplied with kit , any differences ???
Sorry guys for all the questions , not a happy camper right now , missing out on a car show today
[Re: bee1971]
#2103641
07/04/16 02:04 PM
07/04/16 02:04 PM
roadhazard
Akron, Ohio U.S.A.
Rear main seal leaks 100 times worse now then the one it replaced Sorry to hear that.
New 402 oil pan and superformance gaskets are awesome Thanks for noticing the quality difference and your support!
Only thing I didn't do was silicone the sides of billet retainer because I thought that was the purpose of the double o rings , you know to keep oil from leaking by the o rings IMO any seal worth it's salt should not need the aid of sealers.
Anyways I am beyond pissed Can't blame ya
Any better o ring material for those side seals that I can pick up locally ??? They fit in the tiny holes on the end of retainer nicely to hold in place , but coming down the sides you have to keep them in place in the grooves while sliding down the retainer inward on the block , wish the rubber was a little wider I'm personally not a fan of the double o-ring cord, very difficult to work with
Should I offset the rear seal more then a 1/8" so it's not flush with the parting line of block Offsetting more than 1/8" is not going to gain you anything. The purpose of offsetting is to be assured of seal half alignment.
Also the superformance rear main seal versus the Mancini rear seal supplied with kit , any differences ??? I have no idea but can say that the Superformance Products rear main seal is a factory O.E.M Chrysler part.
Sorry guys for all the questions , not a happy camper right now , missing out on a car show today Only suggestion I have is to tear back into it being mindful upon disassembly to watch for clues to what may have gone wrong. My best guess from miles away is the o-ring cord is possibly folded under the retainer, not allowing it to sit flush on the block. Find a retainer that uses the factory style grooves and install the Superformance retainer seals, they work.
[Re: roadhazard]
#2103946
07/04/16 09:29 PM
07/04/16 09:29 PM
bee1971
Sobieski Wi
Thanx guys
Took it apart early this morning
Looked like oil getting past side retainer o rings , and I didn't clock the two piece seal like I thought . It was seated flush or parrellell with block lines
Not happy with my factory retainer ,, looks pretty beat up
Does Mopar or someone reproduce factory retainers ??? Hopefully i don't need to head in that direction
So found some other threads , research
I made sure this time I clocked the rear main seal itself , then did a dry fit with the billet retainer using the alignment rods
Did this dry fit a few times
However upon suggestion , I used black rtv on the sides of the billet retainer , and a little on the bottom ends
The superformance gaskets , I was able to use a putty knife on the four small spots of rtv to separate the gasket from the block . Sweet , came apart perfect , very very nice
Will fire it up tomorrow or in a few days
If this doesn't work
There will Bee a 71 Bee at the local dump
