who makes good valves for reasonable price #1730589
01/15/15 01:22 PM
01/15/15 01:22 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
don't know what indy sells,but I don't want those again. been lookin at the ferrea valves. any good?
Re: who makes good valves for reasonable price [Re: mopar dave] #1730590
01/15/15 01:37 PM
01/15/15 01:37 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I used Ferrea in most builds. Whenever I see a head advertised " With quality stainless valves"
I always think what does that mean? High quality, low quality?
I would want to know exactly what they are
Ferrea 6000 series are nice for the money.
Keith
Re: who makes good valves for reasonable price [Re: Dunnuck Racing] #1730591
01/15/15 01:57 PM
01/15/15 01:57 PM
Mt Morris Michigan
Mt Morris Michigan
6000's are the ones i'm looking at. thank you
Re: who makes good valves for reasonable price [Re: mopar dave] #1730592
01/15/15 02:51 PM
01/15/15 02:51 PM
Locomotion Offline
Locomotion  Offline
Milodon has a couple of choices, which are going into a new engine I'm getting together - small block. They have straight stem Street as well as their necked-down Megaflow
versions:
Milodon small block valves at Summit.
Re: who makes good valves for reasonable price [Re: Locomotion] #1730593
01/15/15 02:54 PM
01/15/15 02:54 PM
Renton Washington
Triple Threat Offline
Renton Washington
Manley Severe Duty in both my sets of heads.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: who makes good valves for reasonable price [Re: Triple Threat] #1730594
01/15/15 04:48 PM
01/15/15 04:48 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
REV Racing Engine Valves in Florida have served me well for years.
If you like drag racing, support your local track.
Re: who makes good valves for reasonable price [Re: CHAPPER] #1730595
01/15/15 04:59 PM
01/15/15 04:59 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i'v looked at the manley and milodon. how much are the rev for 8 2.100 int. valves?
Re: who makes good valves for reasonable price [Re: mopar dave] #1730596
01/15/15 05:11 PM
01/15/15 05:11 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
REV
Ph.# 561-650-0090
800-398-6348 I don't have a current price sheet and do not know all the specs of the valve you want. Call and they can price them out to you. DON'T get too stressed out if you get someone that doesn't speak too good English,,,hang in there, they are good to deal with and are good valves.
I just checked, they do have a catalog on line...google REV Racing Engine Valves and shop away!!
Re: who makes good valves for reasonable price [Re: CHAPPER] #1730597
01/15/15 05:25 PM
01/15/15 05:25 PM
Hard to support Indy but...the valves they used to use were BBB -- BBB will build to any spec you want and provided a great valve when I sold Indy--hard chrome on the stem and a hardened tip is about all you can ask for and all you need if you are not forced induction etc
That company was in Argentina and provided valves world wide to many OEM mfg's They are good valves
All that being said Todd at Marsh Perf sells Manley Severe Duty for Indys for reasonable price if you desire an upgrade in quality
I have always said--if you don't bang the valve into something a $2 will do just fine IMO
Cheaper valves tend to develop a little ridge at the lock groove once assembled or run this needs to be sanded or filed just a tad before disassembly and dragging it through a nice guide but honest I have done some wild wonderful engines with STOCK valves--there is little sense in spending big $$ on them in a normal build.
Now if you have a NOS, Blown, alky or whatever well...that is different
Guide not too tight, high quality seal properly installed, rocker geometry best you can get it are the keys..oh..and don't let the valve hit anything. Thing is IF it does it will bend--the old "dropped a valve " line is when that valve beats that piston until it just can't take it anymore and finally the head comes off--if it did not hit it is Very rare that a valve just fails as a bad part IMO
High dollar valves are made from tougher alloy, have good hard chrome on the stems but BBB ain't no junk maker
Problems with valves are usually not the valves fault from what I see in our shop.
Manley is hard to beat as an upgrade!
Re: who makes good valves for reasonable price [Re: mopar dave] #1730598
01/15/15 05:30 PM
01/15/15 05:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
From what I've seen first hand...
Good:
- Ferrea (a couple of different series)
- Manley Pro Flow
Average (not finished nearly as nicely as the "Good" ones):
- SI (whatever their necked-down & swirl-polished series is)
Never had any REV that I know of, but I've heard them compared favorably to Ferrea & Manley.
Re: who makes good valves for reasonable price [Re: BradH] #1730599
01/17/15 01:11 PM
01/17/15 01:11 PM
ky
68roadrunner Offline
ky
Good:
- Manley Pro Flow
so are the si valves decent to use, i know they didnt used to be very expensive
Re: who makes good valves for reasonable price [Re: 68roadrunner] #1730600
01/18/15 03:13 PM
01/18/15 03:13 PM
BradH Offline
BradH  Offline
Good:
- Manley Pro Flow
Application?
