Page 2 of 4 1 2 3 4
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: gregsdart] #1730119
01/15/15 02:07 AM
01/15/15 02:07 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
P5153816AB
The price I got on 10/26/14 -
927.00 + 16.95 shipping (?)for a total of $943.95
Monicatti Dodge or K & S performance, Kevin 248 439 0261
https://www.monicattichrysler.com
That's 10% off MSRP.
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: 72Swinger] #1730120
01/15/15 09:45 AM
01/15/15 09:45 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
what is wrong with the vvt blocks?
Nothing if your name is Steff lol!
LOL!
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: sixpackgut] #1730121
01/15/15 10:17 AM
01/15/15 10:17 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I will hold out to see what mopar-wholesale sells them for but i'm going to get one. Ever since 340Rick posted pictures of his pistons, I wanted to build another one. Ill save the Apache heads for the next build
Yes, mine is now 4.09 but I have some cylindet walls under .1
I don't think you can compare the sonic #s with the old standard.
Most of the production blocks are thin but hold up very well. I think it may be the high nickel content of the new blocks
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: STEFF] #1730122
01/15/15 11:34 AM
01/15/15 11:34 AM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
LOL!
at least reading some of these comments I now know why you were driven to fab up that belt drive!
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: J_BODY] #1730123
01/15/15 12:07 PM
01/15/15 12:07 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
So are these new 6.1 blocks VVT?
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: Quickrunner] #1730124
01/15/15 12:10 PM
01/15/15 12:10 PM
gregsdart Offline OP
no
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: gregsdart] #1730125
01/15/15 01:44 PM
01/15/15 01:44 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: gregsdart] #1730126
01/15/15 03:28 PM
01/15/15 03:28 PM
Quickrunner Offline
Quickrunner  Offline
no
In that case I may look into getting one myself and just use this 5.7 block I have for mock up in the car.
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: sixpackgut] #1730127
01/15/15 03:37 PM
01/15/15 03:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
947 from mopar-wholesale
http://www.factorymoparparts.net/oe-mopar/p5153816ab?search_str=P5153816AB
I wonder if I can still get 25% off being a Chrysler
employee/retiree... I use to over at Monticotti
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: MR_P_BODY] #1730128
01/15/15 05:53 PM
01/15/15 05:53 PM
STEFF Offline
STEFF  Offline
This is great news!! These new 6.1 blocks will render the 6.4 VVT blocks worthless to the aftermarket and I can buy them for pennies on the dollar!!
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: STEFF] #1730129
01/15/15 05:55 PM
01/15/15 05:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
what I'm wondering is, how thick are the cylinder bores in the 5.7 blocks? is there any difference between the 6.1 and 5.7 at all?
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: sixpackgut] #1730130
01/15/15 06:36 PM
01/15/15 06:36 PM
aZLiViN
aZLiViN
"IF" I were buying $920..... $1030 list. Shows 12 on backorder and no promised release date at the dealer level.
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: sixpackgut] #1730131
01/15/15 08:28 PM
01/15/15 08:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Some have said the early 5.7's could go to 4.00 bore pretty easy. The 6.1 ALL had 6.1 cast in the skirt by the pan rail and they ALL had oil jets installed. If you are wondering about wall thickness, I wouldn't be surprised if they are similar.
Mopar to the bone!!!
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: J_BODY] #1730132
01/15/15 09:03 PM
01/15/15 09:03 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So I guess if you want this guys you need to generate some more back orders.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: 1967dartgt] #1730133
01/15/15 10:44 PM
01/15/15 10:44 PM
aZLiViN
aZLiViN
That's what I'm sayin! I was a little too late on the 2nd R3 I tried to order.
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: J_BODY] #1730134
01/15/15 11:42 PM
01/15/15 11:42 PM
Los Angeles, California
mdeane Offline
mdeane  Offline
The early 5.7's were never designed for anything more then what they did and as soon as they started going over 400 hp the cylinders would not stay round. That's part of the reason SRT came out with the 6.1's so they could design in reinforcements inside the casting to increase the structural integrity that was needed for the increase in horsepower.
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: mdeane] #1730135
01/15/15 11:58 PM
01/15/15 11:58 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
tell him to make us small block guys some blocks then
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: mdeane] #1730136
01/16/15 01:07 AM
01/16/15 01:07 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I don't know about that, the early 5.7's (03-05) are supposed to be the beefiest of the early blocks and plenty of them well over 600 HP and I've never heard of a cylinder wall distortion issue, especially at 400 HP, which is pretty low. As a matter of fact the 5.7 is supposed to have beefier cylinder walls than a 6.1 as a general rule. The 6.1 was designed on its own merit and not because of a "problem" with the 5.7, I'd even guess the 6.1 was designed almost side by side with the 5.7 at the onset of Gen III HEMI design (2000 ish?)
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: WO23Coronet] #1730137
01/16/15 11:31 AM
01/16/15 11:31 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Now a 6.1 block with a 5.7 bore that would be feasible. And have plenty of meat
Matt
Re: 6.1 blocks are coming,,,,,,,,,,, [Re: MattW] #1730138
01/16/15 12:59 PM
01/16/15 12:59 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I've never seen anything happen to a block in either format.
I've seen really bad machine work kill a 426 and I've seen stock block 5.7's go low 11's in a 4000+ car.
All of these block issues are nothing billet mains and a 1/3 fill wont fix. It's been done and it works.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Page 2 of 4 1 2 3 4
