Re: 6.1 blocks are coming,,,,,,,,,,,
[Re: gregsdart]
#1730119
01/15/15 02:07 AM
01/15/15 02:07 AM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
P5153816AB The price I got on 10/26/14 - 927.00 + 16.95 shipping (?)for a total of $943.95 Monicatti Dodge or K & S performance, Kevin 248 439 0261
https://www.monicattichrysler.com
That's 10% off MSRP.
[Re: 72Swinger]
#1730120
01/15/15 09:45 AM
01/15/15 09:45 AM
Posts: 3,874 Smyrna, South Carolina
STEFF
what is wrong with the vvt blocks?
Nothing if your name is Steff lol!
LOL!
[Re: sixpackgut]
#1730121
01/15/15 10:17 AM
01/15/15 10:17 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I will hold out to see what mopar-wholesale sells them for but i'm going to get one. Ever since 340Rick posted pictures of his pistons, I wanted to build another one. Ill save the Apache heads for the next build
Yes, mine is now 4.09 but I have some cylindet walls under .1
I don't think you can compare the sonic #s with the old standard. Most of the production blocks are thin but hold up very well. I think it may be the high nickel content of the new blocks
[Re: STEFF]
#1730122
01/15/15 11:34 AM
01/15/15 11:34 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
LOL!
at least reading some of these comments I now know why you were driven to fab up that belt drive!
[Re: J_BODY]
#1730123
01/15/15 12:07 PM
01/15/15 12:07 PM
Posts: 625 Indianapolis In. usa
Quickrunner
So are these new 6.1 blocks VVT?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: Quickrunner]
#1730124
01/15/15 12:10 PM
01/15/15 12:10 PM
Posts: 10,024 Frostbitefalls MN (Rocky&Bullw...
gregsdart
no
[Re: gregsdart]
#1730125
01/15/15 01:44 PM
01/15/15 01:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: gregsdart]
#1730126
01/15/15 03:28 PM
01/15/15 03:28 PM
Quickrunner
no
In that case I may look into getting one myself and just use this 5.7 block I have for mock up in the car.
[Re: sixpackgut]
#1730127
01/15/15 03:37 PM
01/15/15 03:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
947 from mopar-wholesale
http://www.factorymoparparts.net/oe-mopar/p5153816ab?search_str=P5153816AB
I wonder if I can still get 25% off being a Chrysler employee/retiree... I use to over at Monticotti
[Re: MR_P_BODY]
#1730128
01/15/15 05:53 PM
01/15/15 05:53 PM
STEFF
This is great news!! These new 6.1 blocks will render the 6.4 VVT blocks worthless to the aftermarket and I can buy them for pennies on the dollar!!
[Re: STEFF]
#1730129
01/15/15 05:55 PM
01/15/15 05:55 PM
sixpackgut
Charleston
what I'm wondering is, how thick are the cylinder bores in the 5.7 blocks? is there any difference between the 6.1 and 5.7 at all?
[Re: sixpackgut]
#1730130
01/15/15 06:36 PM
01/15/15 06:36 PM
J_BODY
aZLiViN
"IF" I were buying $920..... $1030 list. Shows 12 on backorder and no promised release date at the dealer level.
[Re: sixpackgut]
#1730131
01/15/15 08:28 PM
01/15/15 08:28 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Some have said the early 5.7's could go to 4.00 bore pretty easy. The 6.1 ALL had 6.1 cast in the skirt by the pan rail and they ALL had oil jets installed. If you are wondering about wall thickness, I wouldn't be surprised if they are similar.
Mopar to the bone!!!
[Re: J_BODY]
#1730132
01/15/15 09:03 PM
01/15/15 09:03 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
So I guess if you want this guys you need to generate some more back orders.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1730133
01/15/15 10:44 PM
01/15/15 10:44 PM
J_BODY
aZLiViN
That's what I'm sayin! I was a little too late on the 2nd R3 I tried to order.
[Re: J_BODY]
#1730134
01/15/15 11:42 PM
01/15/15 11:42 PM
Posts: 16 Los Angeles, California
mdeane
The early 5.7's were never designed for anything more then what they did and as soon as they started going over 400 hp the cylinders would not stay round. That's part of the reason SRT came out with the 6.1's so they could design in reinforcements inside the casting to increase the structural integrity that was needed for the increase in horsepower.
[Re: mdeane]
#1730135
01/15/15 11:58 PM
01/15/15 11:58 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
tell him to make us small block guys some blocks then
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: mdeane]
#1730136
01/16/15 01:07 AM
01/16/15 01:07 AM
Posts: 4,258 Canada
WO23Coronet
Canada
I don't know about that, the early 5.7's (03-05) are supposed to be the beefiest of the early blocks and plenty of them well over 600 HP and I've never heard of a cylinder wall distortion issue, especially at 400 HP, which is pretty low. As a matter of fact the 5.7 is supposed to have beefier cylinder walls than a 6.1 as a general rule. The 6.1 was designed on its own merit and not because of a "problem" with the 5.7, I'd even guess the 6.1 was designed almost side by side with the 5.7 at the onset of Gen III HEMI design (2000 ish?)
[Re: WO23Coronet]
#1730137
01/16/15 11:31 AM
01/16/15 11:31 AM
MattW
Ontario Canada
Now a 6.1 block with a 5.7 bore that would be feasible. And have plenty of meat
Matt
[Re: MattW]
#1730138
01/16/15 12:59 PM
01/16/15 12:59 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I've never seen anything happen to a block in either format.
I've seen really bad machine work kill a 426 and I've seen stock block 5.7's go low 11's in a 4000+ car.
All of these block issues are nothing billet mains and a 1/3 fill wont fix. It's been done and it works.
