Re: 6.1 blocks are coming,,,,,,,,,,,
[Re: AlexP]
#1730139
01/16/15 05:20 PM
01/16/15 05:20 PM
Posts: 4,258 Canada
WO23Coronet
Canada
Are the mains a weak spot in the Gen III's?
[Re: WO23Coronet]
#1730140
01/16/15 06:19 PM
01/16/15 06:19 PM
Posts: 656 Florida
CJD AUTOMOTIVE
The early 5.7's were never designed for anything more then what they did and as soon as they started going over 400 hp the cylinders would not stay round. That's part of the reason SRT came out with the 6.1's so they could design in reinforcements inside the casting to increase the structural integrity that was needed for the increase in horsepower.
I don't know about that, the early 5.7's (03-05) are supposed to be the beefiest of the early blocks and plenty of them well over 600 HP and I've never heard of a cylinder wall distortion issue, especially at 400 HP, which is pretty low. As a matter of fact the 5.7 is supposed to have beefier cylinder walls than a 6.1 as a general rule. The 6.1 was designed on its own merit and not because of a "problem" with the 5.7, I'd even guess the 6.1 was designed almost side by side with the 5.7 at the onset of Gen III HEMI design (2000 ish?)
Actually the block was ready for 2002 production in trucks, but Mercedes having just acquired Chrysler, did not like the fact that the block did not have MDS provisions, and didn't want two different blocks. The redesign is what delayed the 5.7 until 2003, and why the 5.9 Magnum was used instead. My understanding is that SRT group designed the 6.1 to their specs. SRT and Mopar Performance are separate groups that didn't (maybe still don't) play well together. MP wanted to release the 6.1 as a crate motor, but SRT wasn't having it. MP then stroked a 5.7 and offered it carb'd or injected, if I remember something over 500 HP. This started a [Edited by Moparts - Family Friendly Site - Keep it clean] storm between SRT and MP. As you can see, 6.1 blocks will be available now that SRT is done with them. 6.2 and SRT 6.4's are available now, but only as short blocks in the 4K range.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1730141
01/16/15 06:25 PM
01/16/15 06:25 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The 392/540hp crate were 6.1 based with 3.79 cranks.
Mopar to the bone!!!
[Re: WO23Coronet]
#1730142
01/16/15 06:56 PM
01/16/15 06:56 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I don't think so. BES ran a 5.7 with stock bolts and caps. 700hp ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MattW]
#1730143
01/16/15 07:47 PM
01/16/15 07:47 PM
Posts: 72 San Angelo, Texas
Cevidicus
San Angelo, Texas
I wouldn't mind buying a 6.2 short block. Would be a great foundation for a turbo motor.
Anybody have a part number for one or a link?
[Re: 72Swinger]
#1730144
01/16/15 09:37 PM
01/16/15 09:37 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Yes, I meant before the release. The 5.7 stroker made almost 600 HP. SRT and MP then got together on the 6.1.
I was still a dealer tech at the time but got to go to the Mothership at Sterling Heights on several occasions and talk with the engineers. Not sure how much is true, but was told roughly the same from a few different engineers.
[Re: Cevidicus]
#1730145
01/16/15 09:41 PM
01/16/15 09:41 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Part number is 68262362AA. They have it on STAR restriction for QC. You'll need a VIN from a Hellcat and request the part based on other than warranty issue, i.e. hydro-lock from water crossing, etc...
#1730146
01/22/15 11:50 PM
01/22/15 11:50 PM
Posts: 16 Los Angeles, California
mdeane
The information on the early 5.7 blocks going out of round over 400 hp and creating the reason for the development of the 6.1's came directly from one of the SRT engineers.
[Re: MattW]
#1730147
01/23/15 12:15 AM
01/23/15 12:15 AM
Posts: 486 IL
knyech1
IL
Typically the cylinders will crack under higher hp. Have seen some crack at 750 and some live past 1200hp, fairly dependent on tune.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
[Re: knyech1]
#1730148
01/23/15 06:21 AM
01/23/15 06:21 AM
Posts: 22 NE OHIO
SRT440DUSTER
NE OHIO
I wouldnt be so quick to write off the vvt's. High horse performance just posted a dyno graph of a 5.7 with comp cams 274 , cam phaser and full exhaust making 442 hp and 413ftlbs at the wheel.
[Re: SRT440DUSTER]
#1730149
01/23/15 08:13 AM
01/23/15 08:13 AM
72Swinger
Nebraska
They did, about 2 years ago. VVT's are just as good as any older Gen III just more $$$$ and headache for the average hot rodder to use with whats currently available. The one thing about them is if you score one, the worst head it would have is the Eagle which is as good as a W5.
[Re: mdeane]
#1730150
01/23/15 01:24 PM
01/23/15 01:24 PM
Posts: 4,258 Canada
WO23Coronet
Canada
Maybe so, but history says otherwise, PLENTY of 5.7's over 400 HP (well over) with no issues
[Re: gregsdart]
#1730151
02/12/15 06:38 AM
02/12/15 06:38 AM
Posts: 628 Denison,Ia.
Cuda367
Denison,Ia.
Any news now on ship date. I have one on order and received a ship date of feb 4then moved to 10th then 17th and now no date indicated. Have you heard anything?
[Re: Cuda367]
#1730152
02/12/15 10:38 AM
02/12/15 10:38 AM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Some time ago I was told late Feb, early March. Who gave you a ship date?
[Re: gregsdart]
#1730153
02/12/15 10:57 AM
02/12/15 10:57 AM
Cuda367
Denison,Ia.
The dealer I ordered it from received the notice or information. He received it from Chrysler.
[Re: Cuda367]
#1730154
02/13/15 09:40 AM
02/13/15 09:40 AM
gregsdart
That is good to hear. We should get them SOME day!
[Re: gregsdart]
#1730155
02/15/15 01:53 PM
02/15/15 01:53 PM
Posts: 3,428 Toronto
mshred
Toronto
Does anyone know if these blocks are finish machined? Cam bearings installed? If so, I think I am in for a few! Where are you guys ordering from??? I just got my Apache heads today, so the flame has been lit again! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: mshred]
#1730156
02/15/15 02:54 PM
02/15/15 02:54 PM
MattW
Ontario Canada
Matthew My understanding is that they are fully machined ![](/ubbthreads/images/graemlins/thumbs.gif)
I'm thinking that they (Fiat) is probably waiting to see how many orders to fill before the production starts? ![](/ubbthreads/images/graemlins/shruggy.gif)
At the price that they were quoting they will sell a bunch. IMO
[Re: MattW]
#1730157
02/15/15 04:22 PM
02/15/15 04:22 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
what is the price for a fully machined 6.1 block?
[Re: mcat4321]
#1730158
02/15/15 04:38 PM
02/15/15 04:38 PM
MattW
Ontario Canada
1st page 3rd thread.
