6.1 blocks are coming,,,,,,,,,,,
#1730099
01/14/15 11:16 PM
01/14/15 11:16 PM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I got a phone message from Kevin Moore today. He received an email from Mopar saying the 6.1 blocks ought to be out late Feb, early March. Great news! At less than a grand, a brand new block honed to 4.055 only needing cam bearings! My motor will be 401.68 cubes, a bit better for the Apache heads!
Re: 6.1 blocks are coming,,,,,,,,,,,
[Re: gregsdart]
#1730100
01/14/15 11:42 PM
01/14/15 11:42 PM
Posts: 728 Southern Alberta
Uberpube
Southern Alberta
[Re: gregsdart]
#1730101
01/15/15 12:03 AM
01/15/15 12:03 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
What about 6.4 blocks or are they the smae block?
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: Uberpube]
#1730102
01/15/15 12:09 AM
01/15/15 12:09 AM
gregsdart
P5153816AB The price I got on 10/26/14 - 927.00 + 16.95 shipping (?)for a total of $943.95 Monicatti Dodge or K & S performance, Kevin 248 439 0261 https://www.monicattichrysler.com
[Re: slammedR/T]
#1730103
01/15/15 12:14 AM
01/15/15 12:14 AM
gregsdart
09 and up 5.7 and 6.4 are both Variable valve timing (VVT) blocks, which have different cams, covers, and cranks. They need more room up front to package all this, so the front of the block is different. Not sure on the cranks, but they need a different shape on the front, not sure how that is accomplished.
[Re: gregsdart]
#1730104
01/15/15 12:21 AM
01/15/15 12:21 AM
slammedR/T
how far can you bore a 6.1 block?
[Re: gregsdart]
#1730105
01/15/15 12:25 AM
01/15/15 12:25 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
They,Mopar, have said they NEVER re-cast ANYTHING without revisions/improvements. I hope one of those is a cylinder thick enough to 4.20 ish. THAT would be a step in the right direction. Maybe they have applied some of the same cooling tweaks as the Hellcat block. The old 6.1 blocks were simply assembly line blocks left over when they switched to the 6.4 in 2010-11. I have no desire to buy a VVT block of any kind.
Mopar to the bone!!!
[Re: slammedR/T]
#1730106
01/15/15 12:26 AM
01/15/15 12:26 AM
gregsdart
I here about .020 is it. The only other option for a non VVT block is the aluminum block, ($4,000) which I believe can go 4.185?
[Re: slammedR/T]
#1730107
01/15/15 12:28 AM
01/15/15 12:28 AM
72Swinger
Nebraska
Rays is 4.09 I believe. That is about it on those. Hopefully these new ones AT LEAST have 6.4 sleeves that start at 4.09.
[Re: 72Swinger]
#1730108
01/15/15 12:31 AM
01/15/15 12:31 AM
slammedR/T
what is wrong with the vvt blocks?
[Re: gregsdart]
#1730109
01/15/15 12:33 AM
01/15/15 12:33 AM
gregsdart
[Re: slammedR/T]
#1730110
01/15/15 12:39 AM
01/15/15 12:39 AM
72Swinger
Nebraska
Nothing if your name is Steff lol! Cams are expensive and timing chains are subject IMO. They need the VVT feature locked out or deleted for the hot rodder. Quality of them is good to go though, just more of headache and $$$ for no advantage other than availability.
[Re: gregsdart]
#1730111
01/15/15 12:41 AM
01/15/15 12:41 AM
slammedR/T
I read the 6.4 blocks have better cooling and bigger bore capabilitys than the 6.1 blocks, is this true? if so why not run the 6.4 block even though they are vvt?
[Re: 72Swinger]
#1730112
01/15/15 12:43 AM
01/15/15 12:43 AM
Posts: 1,545 USA
hudsonhornet7x
USA
I have a 6.4 short block I am building and from what I gather the Hellcat has nearly identical timing chains as the 6.4. I remember there being problems with the 5.7 but has anyone heard of or seen a problem with the 6.4 chain?
[Re: slammedR/T]
#1730113
01/15/15 12:46 AM
01/15/15 12:46 AM
Posts: 1,545 USA
hudsonhornet7x
USA
A.C. Nutter has come up with a solution for us hot rodders that want to use a pre-vvt cam in a vvt block. Gets rid of it and also uses a different timing chain from what I understand. http://www.nutterracingengines.com/
[Re: slammedR/T]
#1730114
01/15/15 12:54 AM
01/15/15 12:54 AM
72Swinger
Nebraska
Honestly just sit tight and see what this new 6.1 block turns out to be. The aftermarket support sucks for the Gen III market as a whole but it really sucks more for the VVT blocks. Only failure I have seen is a guy with a Procharged 426" 6.4 do a REALLY long, like 10 minutes, WOT run and it seized the middle cam bearing, sheared the cam dowel and the rest is history. But the chain was fine lol! Im not even sure if the cam bearings are even serviceable on the VVT blocks.
[Re: hudsonhornet7x]
#1730115
01/15/15 12:55 AM
01/15/15 12:55 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I'm buying one.
Start another motor before I fire this one...sure why not.
[Re: 72Swinger]
#1730116
01/15/15 12:56 AM
01/15/15 12:56 AM
slammedR/T
Sounds like a good idea ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 72Swinger]
#1730117
01/15/15 01:12 AM
01/15/15 01:12 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Man I hope your right! What would be the purpose of recasting an old block? Warranty? They could of kept the ones they sold to INDY for dirt cheap! I'm hoping they added some meat to the thing ![](/ubbthreads/images/graemlins/thumbs.gif) Matt
[Re: MattW]
#1730118
01/15/15 01:23 AM
01/15/15 01:23 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I will hold out to see what mopar-wholesale sells them for but i'm going to get one. Ever since 340Rick posted pictures of his pistons, I wanted to build another one. Ill save the Apache heads for the next build
Yes, mine is now 4.09 but I have some cylindet walls under .1
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
