Page 4 of 8 1 2 3 4 5 6 7 8
Re: acetone in da gas????? [Re: dart_sportsatellite] #17285
09/26/05 08:38 PM
09/26/05 08:38 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Dart-sport Satellite,what brand of gasoline did your friends use?? which worked best?
Re: acetone in da gas????? [Re: 67_Satellite] #17286
09/26/05 10:17 PM
09/26/05 10:17 PM
twin cities
dart_sportsatellite Offline
twin cities
Not sure what brand of gas he is using, I'll ask. Here's a link with a lot of info, including testing and a scan gauge. Interestingly, one of the tests shows that a 92 Acura Integra saw a 1.1 percent mileage decrease.
http://peswiki.com/index.php/Directory:Acetone_as_a_Fuel_Additive
Re: acetone in da gas????? [Re: 67_Satellite] #17287
09/28/05 09:19 PM
09/28/05 09:19 PM
twin cities
twin cities
Talked to him today, he uses whatever gas is convenient. When he first started testing the acetone mix, he went around to a bunch of stations to find which gas gave him the best mileage for HIS car. After he found this out, he proceded to test how much acetone would give him the best improvement. He started at 1/4 oz. per 10 gals. and worked up to where the mileage dropped off, then back down to where the mileage was best. He's using 2 and 1/4 oz. per 10 gallons, and now buys his gas wherever is convenient.
Re: acetone in da gas????? #17288
09/30/05 12:46 AM
09/30/05 12:46 AM
Anonymous OP
Anonymous OP
Just thought i would pass along that since my last post on Sept 17th that i have gained 1 mpg so far in my 2000 300M. After two tankfulls, the first gaining 4 tenths of a gallon to 24.7 till today at fill up with 25.3 mpg, a 1 mpg increase from my earlier average. Just for the record, i don't baby this car. I drive anywhere from 65 to 85 mph and higher on the highway when needed if i'm running late for work. My driving is light city, mostly country with some highway. The 300M has a nice 3.5 liter motor with a compression ratio of 9.9 to 1 which i have faithfully supplied with 91 to 93 octane because of a noticable reduction in mileage if run on 87 octane donkey drool. When gas prices went sharply higher, i started carefully using the 87 octane without any complaints from the motor at light to moderate throttle. With acetone i can run the 87 octane and so far i have verified the highest averag mpg that have ever seen even when using 91 to 93 octane. I'm driving to Pittsburg tomorrow so i will get to use a full tank at highway speeds of 65 to 80 mph and will let everyone know what happens. 26 to 27 mpg has been the norm for this trip in the past. 28 mpg without the airconditioner at 75 miles per hour average.
One more experience has been what feels to be more responsivness when rolling the throttle down just off of the cruise position. This could be a sighn that the computer is giving full advance that was taken away because of the use of 87 octane to cut back on fuel costs. Gas stations around here are charging 30 cents a gallon more for high test which would be an extra $4.50 for a 15 gallon fill up. Acetone costs are about 60 to 70 cents per tank based on a quart purchased at Walmart around $5.00. If things continue to hold true with further testing, acetone's stated benefits of fuel vapourization could easily exceed what had been seen by the use of expensive hightest fuel.... More to come.
Re: acetone in da gas????? #17289
10/04/05 08:47 PM
10/04/05 08:47 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
ohh Im back, my pills from the other night wore off dont know what I wrote myself???
its not the surface tension its the max total advance available and cooling effect of the solvent.
gas has pretty low surface tension already.
go with Xylene even better carbon chain
any ane or ene is a hydrocarbon diretive and adds . they distill all this stuff off when making the gas then add it afterward to boost .
PS did I tell ya about my 80% acetone burnouts the other night street still looks cool
Re: acetone in da gas????? [Re: HemiGreg] #17290
10/06/05 09:34 AM
10/06/05 09:34 AM
Anonymous OP
Anonymous OP
At highway speeds of up to 85 mph, averaging 73mph for the trip, my big 300M got 28.4 on the way out to Pittsburgh and 28.6 on the way back. I could only guess at what i would get if i kept it on cruise controll at 70mph, 30mpg ??
So far this stuff appears to be doing something as i have never seen these kind of numbers out of this car, especialy at these speeds. Anyone else out there trying this stuff? Results good or bad?
Re: acetone in da gas????? #17291
10/06/05 11:01 AM
10/06/05 11:01 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I have just put 4oz. of acetone into the tank of my 2000 300M. Before, I was getting a consistent 24.3 mpg average according to the factory trip computer, which is pretty darn accurate as found after 110,000 mi. of checking it.
I feel that 24.3 mpg is'nt bad for a nearly 4,00lb vehicle. The only things installed so far was the use of Mobil 1 and a fresh set of plugs. Since i had already started to track mileage and conserve fuel, It will be interesting to see what changes acetone will make as i have'nt seen anyone report any real problems with o2 sensors etc. I bought a quart at Wall Mart for less than 5 bucks which comes out to .15 cents per ounce. I'll let everyone know the good the bad and the ugly
24.3 driving conservative? And you are now not driving for mileage and you get 28.6? If so very cool!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: acetone in da gas????? [Re: Rug_Trucker] #17292
10/06/05 11:45 AM
10/06/05 11:45 AM
St. John's Newfoundland
440newport Online content
440newport  Online Content
So how much did you add a tank of gas? I'm gonna try it on my olds today.
Re: acetone in da gas????? [Re: 440newport] #17293
10/06/05 05:14 PM
10/06/05 05:14 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
I tried in three tank fulls in my 73 charger 318 and it didnt do squat! I was hopin it would but it got the same 16 mpg no matter what...
Re: acetone in da gas????? [Re: Thor500] #17294
10/06/05 08:20 PM
10/06/05 08:20 PM
HemiGreg Offline
HemiGreg  Offline
Awsome link Dart sport thanks.
I think Ill go do some more 100% acetone burnouts ot front of work wish I had a camera here
Re: acetone in da gas????? #17295
10/07/05 01:06 AM
10/07/05 01:06 AM
Anonymous OP
Anonymous OP
What did Hemidan say.!!
Man great thread, but the last post from you Hemidan was way out there.
Dont know ether to write it down as is or ?? ,
Anyway out herer in cali . xylene is cheaper than Tolulene( $10 plus per gal) I did the trick once w. tolulenen and the family 98 GMC ran alot better but was a wash in cost. Going w/ the xylenen next. alot cheaper.
Re: acetone in da gas????? #17296
10/07/05 10:56 AM
10/07/05 10:56 AM
Anonymous OP
Anonymous OP
I just put 3 ounces in my 12 gal Escort tank, I'll report back in 2 weeks when it's time for a fillup. It gets a steady 30mpg now so we'll see.
Re: acetone in da gas????? #17297
10/25/05 12:16 AM
10/25/05 12:16 AM
HemiGreg Offline
HemiGreg  Offline
New Acetone test.
I took my moms 85 lincoln 302 TBI car and ran it till empty (drove it to work on E when i got there idled till it died)
totally empty. then added 1 gallon of pure acetone started car drove 2 blocks and got 10 bucks of gas about 3.5 gallons so now its like 20%. and drove home.
next day my mom calls me and says what did you do to my car, i figure oh oh! , she says it runs like a new engine and flys onto the parkway like never before, this has always been a well tuned low milege car. by end of day she filled it up and she said it lost that zip it had that morning.
geee I wonder how much the Acetone boosted things with absolutley no other changes made to engine/car.
Re: acetone in da gas????? [Re: Quicksilver440] #17298
10/25/05 12:56 AM
10/25/05 12:56 AM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
so..how much does a quart of acetone to 20 gallons of 91 octane gasoline raise the octane?
Easy to figure it out if you know the octane of what you are adding.
Let's say Toluene @ 114 oct. mixing in a 15 gal tank with 93 oct. by adding 1 gal of Toluene:
(93oct x 14gal) + (114oct x 1gal) / 15 gal
So - you'd get 94.4 oct.
You CAN buy Xylene / Toluene in bulk from chemical suppliers. They ARE the main agents in octane boosters. But, as someone said, you should be adding lubricating oil for the added wash-down effect.
I've looked into this (buying bulk chemicals). I found that after you buy all the crap, do the mixing, it would be easier to just buy race fuel and mix if need be.
1967 Satellite, CNC Eddy Headed 500ci Street Mauler
(Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell
2012 Hemi Ram Sport Crew Cab
2011 Avenger, Pentastar V-6
2007 SRT-8 Charger (Dyno'ed @ 470 RWHP)
1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: acetone in da gas????? [Re: Mills] #17299
10/25/05 01:21 AM
10/25/05 01:21 AM
Anonymous OP
Anonymous OP
I lost 5mpg on the first tank of acetone mix.
Re: acetone in da gas????? [Re: Mills] #17300
10/25/05 02:55 AM
10/25/05 02:55 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Yep. And those calculations show why that little can of 104 Octane Booster the autoparts store sells does not make your tank of gas 104 octane.
Re: acetone in da gas????? [Re: GomangoCuda] #17301
10/25/05 11:51 AM
10/25/05 11:51 AM
Anonymous OP
Anonymous OP
so does adding assatone in greater and greater amounts raise the octane more and more? is it more flamable and burn better than just plain gas? what damage does it do the motor in larger amounts. sounds like we have gotten away from a better mpg additive to making our own rocket fuel? if more can make more power it would be fun to do it once in awhile but i don't want to get carried away ether.
Re: acetone in da gas????? [Re: GomangoCuda] #17302
10/25/05 04:34 PM
10/25/05 04:34 PM
Airdrie, AB
Mills Offline
Mills  Offline
Airdrie, AB
Yeah - the concentration of actual octane enhancing products in those boosters are minimal. When they say 2-3 POINTS - they mean 93 to 93.2, not 95. Those boosters work better with the lowest grade fuel as there is a greater differential.
For everyones info - I found the e-mail from the bulk chemical supply house for the Xylene or Toluene. They wanted $102.40 CDN for a 20 Litre can. So, that's about $85 bucks US for 5.3 gallons for my friends south.
I couldn't find pure Toluene / Xylene in hardware stores like everyone said you could (perhaps it is easier to find in the US). I CAN tell you that up here, most places are not just going to give you this stuff after a credit card #....this is used to make explosives.
So, perhaps in the US you can find it cheaper / more readily available. But, I can tell you that the price for that is WAY more expensive then buying / mixing with race gas.
Re: acetone in da gas????? [Re: Mills] #17303
10/26/05 05:22 PM
10/26/05 05:22 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
I am on my 4th tank of adding 100cc of acetone in my 98 neon and it made a big difference.The car has 100,000 mi. and is not maintained that well.I can't remember the last time I changed the plugs!THe car used to ping and rattle and had a slight miss that I thought was a bad coil.Now the piece of crap runs like a top.Haven't measured the mileage but can tell its better because iam getting couple more days out of a tankful.The idle speed has increased to the point I need to do something about it,but don't know how to lower it(I know nothing about computer cars!)If someone can tell me how to lower the idle speed I think the car would get even better mileage.Anybody out there know how to adjust idle speed on a 98 neon single cam?The only thing I know how to do on this car is change head gaskets!
Re: acetone in da gas????? [Re: 540DUSTER] #17304
10/26/05 10:19 PM
10/26/05 10:19 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The idle speed on a Neon is controlled by the computer. If something raised or lowers it, the computer will IAS motor to let in more or less air.
Idle Air Speed.
Even if you load the crank and pull the idle down, the computer will always try to maintain it's goal rpm.
