Thoughts on 372" sb requested. #1729588
01/14/15 05:55 AM
01/14/15 05:55 AM
San Angelo, Texas
Cevidicus Offline OP
San Angelo, Texas
A friend has this 372" small block that's built and ready to go. I just want to get some thoughts on its power potential and what could be expected from it in say a 3400lbs a body. All thoughts and criticisms welcome. I just want to know what y'all think its capable of. Thanks!
372"
340 block .030 over,
360 cast crank with mains turned down to fit,
eagle rods,
KB hyperutectic pistons,12.5:1,
W2 heads ported and flowed 290,
Mopar 1.5 roller rockers,
Howards solid .599/.620 solid cam,
Holley strip Dom intake
Re: Thoughts on 372" sb requested. [Re: Cevidicus] #1729589
01/14/15 11:04 AM
01/14/15 11:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
372"
eagle rods,
That would be about 520hp... JMO
Re: Thoughts on 372" sb requested. [Re: MR_P_BODY] #1729590
01/14/15 11:36 AM
01/14/15 11:36 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Haven't seen good luck with 360 cranks in 340s. Should be a stout motor, high tens if you max the combo.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Thoughts on 372" sb requested. [Re: 1967dartgt] #1729591
01/14/15 11:41 AM
01/14/15 11:41 AM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Cast crank with mains turned down makes me cringe...... but I'll wait for more knowledgeable folks to kick in.
Re: Thoughts on 372" sb requested. [Re: 1967dartgt] #1729592
01/14/15 11:44 AM
01/14/15 11:44 AM
Guitar Jones Offline
I agree on the 10's. I don't know about the crank but I'd think if you kept the RPM's under 7000 it would probably hold up.
Re: Thoughts on 372" sb requested. [Re: J_BODY] #1729593
01/14/15 11:51 AM
01/14/15 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In 73 the 340 had a cast crank... it was just the 1
year then the 340 died
Re: Thoughts on 372" sb requested. [Re: MR_P_BODY] #1729594
01/14/15 12:11 PM
01/14/15 12:11 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
MP/Scat sells a 3.58 stroke 340 main cast crank.
Should be in the 10s...
Tony
70 AARCuda Vitamin C
Re: Thoughts on 372" sb requested. [Re: 70AARcuda] #1729595
01/14/15 12:32 PM
01/14/15 12:32 PM
Earth
Rob C Offline
Rob C  Offline
Earth
That is an old time poor mans stroker combo that has been very effective.
The turned down cast crank should not be a problem if it was proper done and treated correctly. I remember reading a long while back a fella did that combo and topped it with ported Edelbrock heads and a roller. It dyno'd high 500's. A very stout combo.
Re: Thoughts on 372" sb requested. [Re: Cevidicus] #1729596
01/14/15 01:11 PM
01/14/15 01:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What carb..............
Re: Thoughts on 372" sb requested. [Re: Thumperdart] #1729597
01/14/15 03:35 PM
01/14/15 03:35 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Ditch the Eagle rods, unless they're H beams. If you want I beams, RUN AWAY. SCAT for I beams.
Re: Thoughts on 372" sb requested. [Re: 70AARcuda] #1729598
01/14/15 03:39 PM
01/14/15 03:39 PM
cudadoug Offline
cudadoug  Offline
A buddy of mine was going to do this SAME combo. "Poor Man's Stroker"? Well, not so much. GOOD shops were quoting him $500 and up to cut and re heat treat the crank. Bought that MP/SCAT from Jegs for $360-ish.
Re: Thoughts on 372" sb requested. [Re: Cevidicus] #1729599
01/14/15 03:49 PM
01/14/15 03:49 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Get a good crank and use a lot of converter. 10.90's maxed out w/4.86 gear.
Yeah, it's got a smallblock.
Re: Thoughts on 372" sb requested. [Re: Cevidicus] #1729600
01/14/15 08:13 PM
01/14/15 08:13 PM
N. Of Detroit, Mi
733404spdCuda Offline
N. Of Detroit, Mi
My Combo built by MRL Racing
340 Block 4.100"
3.58 Eagle Crank
2.100 Eagle sbc H Beam rods
Diamond Piston 9.7 comp
Edelbrock 63CC Heads CNC ported my MCH
Houghs 1.6 roller rockers
Solid 243/251 duration @ .050" .550/.570 lift
Edelbrock RPM Intake
Kevco pan with baffles
750 quickfuel carb
520HP @ 6200 and 490TQ @4500 on pump gas
Nice street / strip motor
Re: Thoughts on 372" sb requested. [Re: 733404spdCuda] #1729601
01/15/15 12:34 AM
01/15/15 12:34 AM
San Angelo, Texas
San Angelo, Texas
Thanks! What y'all are saying is right about what I was thinking.
Re: Thoughts on 372" sb requested. [Re: Cevidicus] #1729602
01/15/15 03:23 PM
01/15/15 03:23 PM
cudadoug Offline
cudadoug  Offline
Sorry OP, I didn't realize that you said "BULIT" (as in ALREADY BUILT)in your opening post before I started running off at the mouth.
Re: Thoughts on 372" sb requested. [Re: cudadoug] #1729603
01/15/15 05:14 PM
01/15/15 05:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
2250# door car. 9.40s, 30s on a good day. 142-143 MPH. 7200-7400 RPM. 360 crank cut with no other work other than balanced.
I fought rod bearing issues for a long time before doing some work on the oil system. Still had to do bearings at 120 runs, but that's about what I put on it in a year. Just freshen it up over the winter and put it back in.
That was a while ago. Wouldn't do it again with the parts that are available now unless it would maybe be a nice street deal with less RPM. Inexpensive cubic inches.
Re: Thoughts on 372" sb requested. [Re: CMcAllister] #1729604
01/16/15 12:35 AM
01/16/15 12:35 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Basing my comments on my 368" Batten W2 motor Duster:
There's 300-320 CFM in a W2 head. But the flow "curve" matters.
Good intake, same here. I'd prefer a lighter piston with a low-drag ring pack. Hopefully H-beam rods.
Cam sounds a bit small on In and quite offset on Ex...what's the lift specs?
It'll want at least an 850CFM carb.
Depending on tire, 4.88-5.38 gear & proper converter (probably 5500 or so) a W2/372 should go mid/high 10s @ sea level in a 3000-3200-lb A-body.
