performance indicator routing #1729468
01/13/15 11:06 PM
01/13/15 11:06 PM
New Brunswick Canada
copperSwinger Offline OP
how is the vacuum line routed on an abody with a performance indicator?
Thanks!
Re: performance indicator routing [Re: copperSwinger] #1729469
01/13/15 11:39 PM
01/13/15 11:39 PM
The only one I recall was a 60's barracuda with an in dash performance indicator (vac gauge). the vac line ran from it thru the firewall out to a NPT vac tree (may have had only 1 small nipple) in a runner in the rear half of the intake manifold
