Re: Valve weight tech, stainless to titanium difference
[Re: Street Monkies]
#1728215
01/13/15 11:35 PM
01/13/15 11:35 PM
Posts: 41 PA
R5P7 Bantam
PA
The best way to figure out what you need is to put a engine on a spintron. Very expensive and some engine builders have access to them. With this you can find out what valve springs pressures you can run, lifter bounce, how stable the valve train is at high rpm, ect.
Spintron is the way to go.....but first you need to optimize the valve train geometry or you will play 52 pickup with little metal parts. The ideal methodology behind the spintron is to exceed the desired rpm and test for longevity (granted the valve train geometry is fixed / optimized). Then when the desired rpm is utilized, you can feel confident in 2x,3x, etc the extended life of valve train parts.
It's kinda simple to make your own spintron. electric motor and rheostat directly coupled to the camshaft. Hook up the valve train and get an adjustable strobe light (timing light). Once optimized, its just an endurance test.
[Re: R5P7 Bantam]
#1728216
01/13/15 11:55 PM
01/13/15 11:55 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Its WAY over my head as I'm a simple country boy but do you see sizable advantages using titanium valves in a combo like mine? 572 Keith Black 4.500 bore 4.500 stroke B1 head 800 plus lift roller 7000-7500 shift RPM (est) Nitrous
[Re: pittsburghracer]
#1728217
01/14/15 12:09 AM
01/14/15 12:09 AM
Posts: 41 PA
R5P7 Bantam
PA
Sizeable?....define as $ invested per run or $ invested per .01 et gain? Not sure what it means to you.
Here's my assessment: If you're going Ti, go to a 8mm or 7mm stem. Knock out the guides and install new tapered ended bronze guides. They're all over ebay cheap....real cheap, just get the right ones. Then look for proper length valves and do a valve job (most have a different seat angle than you're use to seeing).
Lighter components yield longer life on the reciprocating parts. If you're looking for lots of runs, then good move. If you think you'll be grenading it sooner, then don't invest the time or money. Since you're juicing it, stick with what you have. If you optimize the combo and chassis and you need more, then make the investment.
Good luck either way. Hope this helps?
[Re: R5P7 Bantam]
#1728218
01/14/15 12:42 AM
01/14/15 12:42 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
If you guys want valvetrain stability stop playing with standard size cam cores
BB, TT5,Procharged 3300lb Street Car 4.79/154
