Page 2 of 4 1 2 3 4
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Oyvind Mopar] #1727919
01/13/15 09:46 PM
01/13/15 09:46 PM
In a house near you
Street Monkies Offline OP
In a house near you
When you got cylinder that work efficiently you don't seem to need a high duration cam and all the extra air movement. But yet again you see guys with efficient heads and monster duration cams that turn rpm running real strong. Either set up has to be suited for the combo.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Oyvind Mopar] #1727920
01/13/15 09:50 PM
01/13/15 09:50 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'd think that combo would have ridiculous low end and as the guys on here have pointed out would hold onto the power pretty good, you might've even went to far?
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: WO23Coronet] #1727921
01/13/15 10:00 PM
01/13/15 10:00 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Head flow is king, period. If you've got a good set of heads you will make power.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: GTX MATT] #1727922
01/13/15 10:05 PM
01/13/15 10:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
It's not that simple...
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: BradH] #1727923
01/13/15 10:07 PM
01/13/15 10:07 PM
In a house near you
In a house near you
Correct. Big flow #s and even bigger ports sell heads. Doesn't mean it makes power for a given combination. There is a lot of other important details besides head flow like chamber design, velocity, swirl, port shape, and lot's more.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: GTX MATT] #1727924
01/13/15 10:16 PM
01/13/15 10:16 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Oyvind's combo will make power for sure, just thinking he might've gone to small on the cam as 500+" will eat a lot of duration
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Street Monkies] #1727925
01/13/15 10:23 PM
01/13/15 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If I have a head that peaks flow at (we will say)
.700 lift.. I want a cam thats in the .800+ lift.. you
have a lot more time at the max(you would see the max
twice and all the time over it).. duration is rpm for
our wedge stuff... not really true with the new style
head that has a great velocity ... but I'm still
playing with old junk.. my last set was W-9
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: BradH] #1727926
01/13/15 10:31 PM
01/13/15 10:31 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
... Where you run into limitations is a proportionally huge port (like a Cleveland Boss 302) on a small displacement motor, it's hard to avoid a peaky (light switch) type torque and power curve with that type scenario. you effectively kill as much duration as you can to try to give it some "passable" bottom end....and (like ford) you gear the wee out of it (4.33 gears, etc).
That's along the lines of what I was going to add to my original post about how even a "good" head still needs to have enough cubes & compression under it to make the combination effective.
It's another example of a poor parts combination that looks cool on paper, but doesn't pan out in the real world.
Nothing worse than a great flowing head(300cfm?) that makes 425hp because it's got a tiny cam and other restrictions. My crude rule is if you don't make 2hp per CFM(in a street engine) something is off. Maybe I'm off but that's my street engine yardstick.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Cogito] #1727927
01/13/15 10:34 PM
01/13/15 10:34 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
What controls velocity?
Piston speed and port/runner shape. In essence, the geometric profile (tube) in which the air travels to the base of the valve head. This geometric shape starts at the top of the intake manifold (carb plate) and some may include the shape of the venturi's w/in the carb/throttle body.
This is the response I see most often on the internet.
How about valve events and ramp rates?
Valve timing events are critical. We can get really in depth with this if you like......but for now we'll just keep it basic. As the piston lowers in the cylinder, it "pulls" on the intake port as the valve is opening (the scavenging effect). Just before the piston reaches BDC, the intake valve should close (tightly) thus getting the max cylinder volume of charge (air and fuel). It is very possible to actually achieve more than one atmosphere during this operation w/o forced induction. Then the piston goes up and down, and on the following up stroke it "pushes" the fired charge out the exhaust port.....But, this is where it gets good!!!! The velocity in which it travels out the exhaust while the intake begins to open (split overlap) can actually create a negative charge on the intake chamber thus pulling in the new fuel charge at a greater velocity that standard flow (ie, form of forced inducing). This fills the cylinder as the piston drops and......we're at the beginning. But, possibly more than one atmosphere of volume inn the cylinder = VE approaching and exceeding 100%.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: R5P7 Bantam] #1727928
01/13/15 10:45 PM
01/13/15 10:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is where a GOOD set of headers comes into play
with equal length primaries so it pulls on the
intake charge at the right time.. unlike the off the
shelf headers that fit in the car and thats about it
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: R5P7 Bantam] #1727929
01/13/15 11:02 PM
01/13/15 11:02 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Scavenging happens Here on overlap.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: BradH] #1727930
01/13/15 11:04 PM
01/13/15 11:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Sure its not, or else we wouldn't have aftermarket cams, intake, headers, carbs, etc. But its pretty easy to make power with the right set of heads. The power limit lies in the heads.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: R5P7 Bantam] #1727931
01/13/15 11:05 PM
01/13/15 11:05 PM
In a house near you
In a house near you
Good info. Volumetric efficiency is very important to make power. Usually your street rod motors are only in the 80s and maybe 90s if they got it hyped up. A good all out race engine can start in the upper 90s and go in the 110-115 range. Usually takes a pretty big cam 260+ @ .050 a lot of cr 12:1+, good flowing heads 280+ ect to achieve anything over 100. Who also has good info on this is Rehere Morrison Championship Engine Assembly.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: R5P7 Bantam] #1727932
01/13/15 11:20 PM
01/13/15 11:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
We can get really in depth with this if you like......but for now we'll just keep it basic.......
Just before the piston reaches BDC, the intake valve should close (tightly) thus getting the max cylinder volume of charge.....
Really?
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Street Monkies] #1727933
01/13/15 11:25 PM
01/13/15 11:25 PM
PA
R5P7 Bantam Offline
R5P7 Bantam  Offline
PA
Very true, but we're mixing the pews in the church.
High compression ratios's are not necessarily required for high VE. Also, large duration profiles are not the answer either.
Here's an example:
350 cu in engine Cam in the 260 - 270 deg @ 0.050"
Decent flowing head 10:1 static comp
VE at 6000 rpm < VE at 8000 rpm.
Why?
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: R5P7 Bantam] #1727934
01/13/15 11:49 PM
01/13/15 11:49 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Don't believe everything you read here Brock. There is a LOT of completely wrong information on this post. That and some old school thinking that is irrelevant today.
Keith
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Dunnuck Racing] #1727935
01/14/15 01:27 AM
01/14/15 01:27 AM
In a house near you
In a house near you
That's right Keith you know the game pretty good. For P7 Bantam the VE from what I understand is just how well the motor breathes. Back to the basics of the motor is just a air pump. Air needs brought in and back out and fuel needs brought in and burned. Yes even with a lower cr you can still have a some what high VE with a good camshaft that has good valve timing. Doesn't even have to be real high duration. Lot's of other factors that can pick up where other things lack. The valve timing is very important. I like to think of the valve timing as of how big the camshaft actually is or acts. When valve over lap comes into play it creates a whole new ball game. You can take a cam that's 276/284 @ .050 on a 108° lsa for an example that only has 64° of valve over lap. You can forget those big duration #s at .050 because the way it opens the valves. Now you have some what of a small cam that is set up for say a more efficient cylinder head and geared towards torque. For 6000-8000 rpm if a motor starts to breathe better as the rpm goes up then VE should go up or down depending on the combo. It's just like the curve of how the motor makes hp and tq. It starts off lower then climbs and for a while and maybe quit climbing then maybe it picks back up again. But either way it eventually quits climbing and starts to fall off.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: R5P7 Bantam] #1727936
01/14/15 03:21 AM
01/14/15 03:21 AM
KS
Cogito Offline
Cogito  Offline
KS
Here's an example:
Why?
IVC happens ABDC.
Using the general rule of thumb that peak VE occurs at peak torque (again, in general), I'm curious to know how your example engine could be less VE @ 6k than 8k. Cylinder filling tapers off after peak torque...where max filling occurs...
Some have touched on what I've seen...big efficient ports, low overlap...the intake ports don't need the exhausts help. The advantage to this is greater driveability if a street/strip car...which is what I'm mostly familiar w/.
Don't expect to run an off the shelf cam on a head w/ what are thought of as 'big ports'. Conventional thinking...70s/80s ideas of what cam to use...will lead to the torqueless engines people are warning about.
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: WO23Coronet] #1727937
01/14/15 05:34 AM
01/14/15 05:34 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Yes, I know. I do have some cams on the shelf, and this was the first try. Have not started the engine yet, but if too little cam I have another roller one symmetric at 242 degrees @050 with more lift. But as this is a street engine with manual and OD I would like to try the small first. In this combo I am not looking for high rpm horsepower, but driveability and spare power. I guess I will have a big detonation problem if running on gas. And with the small overlap I guess the headers do not help much either.....
Re: Big Ports, Big Flow #s, And Low Duration Camshafts [Re: Oyvind Mopar] #1727938
01/14/15 11:04 AM
01/14/15 11:04 AM
gregsdart Online content
gregsdart  Online Content
"Very true, but we're mixing the pews in the church.
High compression ratios's are not necessarily required for high VE"
High CRs enhance cylinder fill because the overlap cylinder fill becomes more efficient. With less volume to pull on, the exhaust pulse vacuum can pull more fresh charge earlier increasing overall effectiveness. With the overlap period creating up to five times the draw of the piston at max velocity any change to the package is significant. Look at the latest Hemis, 10.4 or higher compression, big intake ports, very long tuned intake runners, short cam. It all has to be right, but then the power is amazing.
As to how much exhaust tuning helps, I think most know it is huge. Look what happens to hp when a motor is run with Zoomies. If there is no tuned length etc, power goes way down.
Page 2 of 4 1 2 3 4
