Re: Chassis Shops in Ohio
[Re: Mpetros]
#1727211
01/12/15 12:15 AM
01/12/15 12:15 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
Does Hutter do cage work? I thought they did
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: griff70440]
#1727212
01/12/15 12:42 AM
01/12/15 12:42 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Thanks,
I`ll call him tomorrow. How have you been? how`s the car coming along?
Mike Been doing good, thanks. I've driven the Duster many times but still not done yet. It's everything I wanted, just get in it and cruise.
[Re: Mpetros]
#1727215
01/13/15 07:01 PM
01/13/15 07:01 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Advanced Chassis..They are in Antwerp Ohio
NOOOO!!! Not if you value your life, the failure in the picture was a result of them sectioning 4 link brackets to avoid having to cut off housing ends and they did not box it in to add strength. This happened after about a dozen 10 second passes in a 2800lb race weight car that they did a 25.5 cage and back half on. They made good and fixed everything properly and replaced everything that was destroyed from the failure, luckily nobody was hurt as a result, it could have been nasty. But i definitely did not expect something like this to happen after he dropped all the coin with them.
[Re: griff70440]
#1727218
01/19/15 11:55 AM
01/19/15 11:55 AM
ProSport
Akron, Ohio
Bob,
Thanks for the tip. Dennis stopped by on sunday. I`m going to have him do the work on the car.
Mike
Awesome, he does nice work.
