Hemi Cam Questions.
#1727198
01/11/15 05:28 PM
01/11/15 05:28 PM
Posts: 1,249 North Carolina
469runner
North Carolina
I am putting together a 2nd generation HEMI and would like an opinion on the cam I have. This is a 484 ci, ported Stage V heads from Tim Banning, stock 2 plane intake and stock carbs. TTI headers. Comp Cams: Solid Roller, Duration @ .050 236/243, Lift, .603/.552 at valve. Lobe centerline, 113 degrees.
I'm not too familiar with solid rollers. Will this be streetable? Will it have a decent idle? Enough vacuum for power brakes? I got this cam and lifter set with a bunch of other parts purchased. Probably over $1,000 bought new, so would hate to waste it.
Re: Hemi Cam Questions.
[Re: 469runner]
#1727199
01/11/15 07:24 PM
01/11/15 07:24 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
That Hemi will idle like a new caddilac with that cam. It's too small to really take advantage of the heads and the displacement. I'd add about 20 degrees to the duration. A stock intake will cost you a ton of power as well compared to a Stave V dual quad. Good luck, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
