Re: looking for some cam opinions 360 street strip
[Re: Thumperdart]
#1726757
01/11/15 09:43 PM
01/11/15 09:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dom... if he drops your name.. will he get a price break... or a higher price
Going to be TWICE as much, will come w/4 flat lobes and sandpaper to clean the rest up............
Yeah... they'll send him 2 halves... hopefully they match up on the joint..LOL
[Re: MR_P_BODY]
#1726758
01/11/15 09:47 PM
01/11/15 09:47 PM
Posts: 855 ontario canada kingston
aspenrt360
wow flat lobes and two pieces all for the same low price! I will call and see what they say. the pistons should be here tomorrow so I will take the block in to get it bored then we will do a mock up to see about the decking.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: aspenrt360]
#1726759
01/11/15 10:08 PM
01/11/15 10:08 PM
MR_P_BODY
Plus they give you a file to make your own lobes..LOL
[Re: Thumperdart]
#1726761
01/11/15 10:15 PM
01/11/15 10:15 PM
MR_P_BODY
I prefer a grinder.................MUCH faster............
They only rent that out.. file is standard.. LOL
[Re: aspenrt360]
#1726764
01/12/15 12:40 PM
01/12/15 12:40 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I also like the comp xe I ran a milder xe 274 h years ago it was a really nice cam I have heard good stuff about the xe 275hl. anyone here run one?
I ran a xe275hl in my 408 for a couple years. I couldn't get it to hook and Im not an expert on the 4spd at the strip but it consistantly MPH'd at 108.
In the street it was good- it 'turned on' hard at 2200 rpm and pulled to about 5k then quit. In a 360 auto with a little stall it would be perfect. It was really noisy for a hft cam- the closing ramps are really fast and slam the valves shut. My solid cams are quieter.
I eventually had a lifter collapse and swapped the cam out while I was in there.
Radar
[Re: MR_P_BODY]
#1726767
01/12/15 11:16 PM
01/12/15 11:16 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Hung up on, most likely! Kidding, Dom...
On a related note, a know of a 360, with warmed up 596 smogger heads, Eddy Performer, 600 vac sec Holley, and ran the OLD Isky 280 mega cam. .480 lift and added 1.6 rockers to get to .512 on the exhaust.
Car? 73 Challenger, bone stock. Dunlop Qualifers, rally wheels, battery up front...no frame ties. A real everyday driver AND had to have 200+ lbs of audio equipment in it. 3.23 gears.
Stock 904 with a shift kit, stock converter.
$99 Summit headers, cheap turbo muffs and 2.5 exhaust to the rear end.
When it was being built, my only thought was "ho-hum".
Only ran 13.40's, but at 110 MPH! Many, many times.
My point: Isky earned my respect!
[Re: cudadoug]
#1726769
01/13/15 12:14 PM
01/13/15 12:14 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
No not from Howards, I have an older Hughes that has the same timing events but with a little less lift. Had it in a 360 with eddy heads that was in my 73 Duster. With lousy traction and stock converter and 3.23 gears, I had to walk the car off the starting line but would run 102 mph trap speed in Vegas. It had a very nice sound to it also...as if that means anything...Best thing is the price is very nice also....
We used another hydraulic cam from howards in our 71 Duster for awhile until we changed engines. It was 241/241 @ .050 with .562 lift....
And as a side note not wanting change the subject, It looks like Hughes has changed their cam grinder to Howards...New lower price and comparing some of the existing howard grinds to the new hughes grinds...basically the same and Hughes has added more grinds for the SB based on the .904 lifter then howard had.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: cudadoug]
#1726770
01/13/15 02:16 PM
01/13/15 02:16 PM
Thumperdart
State of confusion
Isky rules............ And they LOVE me over there, just ask em...........
