Page 2 of 3 1 2 3
Re: looking for some cam opinions 360 street strip [Re: Thumperdart] #1726757
01/11/15 09:43 PM
01/11/15 09:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dom... if he drops your name.. will he get a price
break... or a higher price
Going to be TWICE as much, will come w/4 flat lobes and sandpaper to clean the rest up............
Yeah... they'll send him 2 halves... hopefully they
match up on the joint..LOL
Re: looking for some cam opinions 360 street strip [Re: MR_P_BODY] #1726758
01/11/15 09:47 PM
01/11/15 09:47 PM
ontario canada kingston
aspenrt360 Offline OP
wow flat lobes and two pieces all for the same low price! I will call and see what they say. the pistons should be here tomorrow so I will take the block in to get it bored then we will do a mock up to see about the decking.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726759
01/11/15 10:08 PM
01/11/15 10:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Plus they give you a file to make your own lobes..LOL
Re: looking for some cam opinions 360 street strip [Re: MR_P_BODY] #1726760
01/11/15 10:13 PM
01/11/15 10:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I prefer a grinder.................MUCH faster............
Re: looking for some cam opinions 360 street strip [Re: Thumperdart] #1726761
01/11/15 10:15 PM
01/11/15 10:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They only rent that out.. file is standard.. LOL
Re: looking for some cam opinions 360 street strip [Re: MR_P_BODY] #1726762
01/12/15 12:55 AM
01/12/15 12:55 AM
nice!
Re: looking for some cam opinions 360 street strip [Re: MR_P_BODY] #1726763
01/12/15 01:47 AM
01/12/15 01:47 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Speaking of files, the last two 8896 3-circuit carbs I converted to 2`s had to have the booster tangs hand filed/profiled cos apparently the venturi radius is different on the older dommys.............3 hours later and all`s well............
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726764
01/12/15 12:40 PM
01/12/15 12:40 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I also like the comp xe I ran a milder xe 274 h years ago it was a really nice cam I have heard good stuff about the xe 275hl. anyone here run one?
I ran a xe275hl in my 408 for a couple years. I couldn't get it to hook and Im not an expert on the 4spd at the strip but it consistantly MPH'd at 108.
In the street it was good- it 'turned on' hard at 2200 rpm and pulled to about 5k then quit. In a 360 auto with a little stall it would be perfect. It was really noisy for a hft cam- the closing ramps are really fast and slam the valves shut. My solid cams are quieter.
I eventually had a lifter collapse and swapped the cam out while I was in there.
Radar
Re: looking for some cam opinions 360 street strip [Re: radar] #1726765
01/12/15 10:48 PM
01/12/15 10:48 PM
hmm I have had a couple of comp xe cams and some made noise others didn't. always set the preload too never understood why some seemed to clatter and others not. they all ran good though.
Re: looking for some cam opinions 360 street strip [Re: qwkmopardan] #1726766
01/12/15 10:54 PM
01/12/15 10:54 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Racer Brown ST-21.
QMD, what would you recommend in a hydraulic Racer Brown grind?
Re: looking for some cam opinions 360 street strip [Re: MR_P_BODY] #1726767
01/12/15 11:16 PM
01/12/15 11:16 PM
cudadoug Offline
cudadoug  Offline
Hung up on, most likely! Kidding, Dom...
On a related note, a know of a 360, with warmed up 596 smogger heads, Eddy Performer, 600 vac sec Holley, and ran the OLD Isky 280 mega cam. .480 lift and added 1.6 rockers to get to .512 on the exhaust.
Car? 73 Challenger, bone stock. Dunlop Qualifers, rally wheels, battery up front...no frame ties. A real everyday driver AND had to have 200+ lbs of audio equipment in it. 3.23 gears.
Stock 904 with a shift kit, stock converter.
$99 Summit headers, cheap turbo muffs and 2.5 exhaust to the rear end.
When it was being built, my only thought was "ho-hum".
Only ran 13.40's, but at 110 MPH! Many, many times.
My point: Isky earned my respect!
Re: looking for some cam opinions 360 street strip [Re: 70AARcuda] #1726768
01/13/15 04:53 AM
01/13/15 04:53 AM
cudadoug Offline
cudadoug  Offline
Howards cams
http://www.summitracing.com/parts/hrs-710581-10/overview/make/plymouth
Interesting. Tony, have you run that cam?? Results?
Re: looking for some cam opinions 360 street strip [Re: cudadoug] #1726769
01/13/15 12:14 PM
01/13/15 12:14 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
No not from Howards, I have an older Hughes that has the same timing events but with a little less lift. Had it in a 360 with eddy heads that was in my 73 Duster. With lousy traction and stock converter and 3.23 gears, I had to walk the car off the starting line but would run 102 mph trap speed in Vegas. It had a very nice sound to it also...as if that means anything...Best thing is the price is very nice also....
We used another hydraulic cam from howards in our 71 Duster for awhile until we changed engines. It was 241/241 @ .050 with .562 lift....
And as a side note not wanting change the subject, It looks like Hughes has changed their cam grinder to Howards...New lower price and comparing some of the existing howard grinds to the new hughes grinds...basically the same and Hughes has added more grinds for the SB based on the .904 lifter then howard had.
Tony
70 AARCuda Vitamin C
Re: looking for some cam opinions 360 street strip [Re: cudadoug] #1726770
01/13/15 02:16 PM
01/13/15 02:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Isky rules............ And they LOVE me over there, just ask em...........
Re: looking for some cam opinions 360 street strip [Re: Thumperdart] #1726771
01/13/15 09:24 PM
01/13/15 09:24 PM
That Howards cam has a lot of lift for the duration compared to the comp. it looks really interesting. I tried calling Isky today could not get through will try again tomorrow.
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726772
01/13/15 09:30 PM
01/13/15 09:30 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
James
Check with Hughes.
There's several there that might be what you are looking for in a hyd cam.
Re: looking for some cam opinions 360 street strip [Re: Blown 68 R/T] #1726773
01/13/15 09:45 PM
01/13/15 09:45 PM
Hey there Kevin. hope you get your heads sorted out soon. got to see that supercharged big block again!
Re: looking for some cam opinions 360 street strip [Re: aspenrt360] #1726774
01/13/15 10:41 PM
01/13/15 10:41 PM
Shannonville, Ont
Shannonville, Ont
Re: looking for some cam opinions 360 street strip [Re: Blown 68 R/T] #1726775
01/13/15 11:55 PM
01/13/15 11:55 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Here is one for Rudy's build.
http://www.hughesengines.com/Index/produ...mp;partid=30244
Hughes
HUG SEH3642AL-8
SB HYD FLAT TAPPET CAM 236/242 -108šLSA
Lift .546/.563
$165.00
Howards
711791-08
236/240 @ .050
lift .547/.558
$125.00 with Free Shipping from Summit.
http://www.summitracing.com/parts/hrs-711791-08/overview/make/plymouth
Tony
Re: looking for some cam opinions 360 street strip [Re: 70AARcuda] #1726776
01/14/15 01:57 AM
01/14/15 01:57 AM
Rudy's car is not in the shop yet Kevin. once i pull the engine i will have to see what kind of shape it is in.then he has to figure out what he really wants from it. it's a stick but heavy too!
Page 2 of 3 1 2 3
