Page 3 of 3 1 2 3
Re: Which Hemi Head? [Re: Mopar_Rich] #1725500
01/28/15 02:01 PM
01/28/15 02:01 PM
dogdays Offline
dogdays  Offline
Hughes has been around a long time, they are MOPAR specialists, don't do any other kind of engine. They popularized the "real Chrysler" cam with lobes that use the 0.904 lifter to advantage. Some members have had extremely good luck with them. Most of the complaints have been when someone from the board caught someone at Hughes on a bad day. But they do know their Mopars.
R.
Re: Which Hemi Head? [Re: Mopar_Rich] #1725501
01/28/15 07:55 PM
01/28/15 07:55 PM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
As for flow numbers i think the NRE X1 H2O Hemi heads exceed the Millenium heads don't they?
Yes they do and so do the BAE fat heads. But these are both billet alcohol heads not made for street use.
NRE X1 H20 heads have water passages. My mate has a set at his shop at the moment that are going on a burnout car.
Re: Which Hemi Head? [Re: OUTLAW565] #1725502
01/28/15 10:03 PM
01/28/15 10:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My ported Canfield heads are in down at the shop. These are the Indy Hipo heads. When I get down there and pick them up I will get them flowed. They claim 480cfm and I will have $3400 into them..I only need 440cfm or so to hit my goal.
As for the eddy heads, got to see a set Saturday, they don't even clear the rivets on the Cometec gaskets...Keep them!
Re: Which Hemi Head? [Re: Dragula] #1725503
01/29/15 01:57 AM
01/29/15 01:57 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Clear the rivets?
$3400 for 480cfm, sign me up! Which Indys are these?
Re: Which Hemi Head? [Re: gsmopar] #1725504
01/29/15 02:35 AM
01/29/15 02:35 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Clear the rivets?
Yeah Cometic has not figured out that the brass rivets that hold the MLS gasket layers together should be moved farther out. It's just one of those things you have to look for that the rivet isn't caught between the head and block. No biggie, I just remove the offending rivet and move on.
Re: Which Hemi Head? [Re: gsmopar] #1725505
01/29/15 08:50 PM
01/29/15 08:50 PM
Dragula Offline
Dragula  Offline
Clear the rivets?
Hipo heads...It lists them with full porting to be 440-480cfm I can post numbers when I get them flowed.
Re: Which Hemi Head? [Re: Dragula] #1725506
01/29/15 11:57 PM
01/29/15 11:57 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Can you elaborate on the eddy head issue????
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Which Hemi Head? [Re: Dragula] #1725507
01/30/15 11:09 AM
01/30/15 11:09 AM
an8sec70cuda Offline
The MP heads don't clear the rivets on Cometic gaskets either...no big deal. Just remove the rivet. That's a pretty poor reason to not use a set of heads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which Hemi Head? [Re: an8sec70cuda] #1725508
02/24/15 12:36 AM
02/24/15 12:36 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
So I see that the FHO stageV cnc ported heads flow 435ish, my stock replacements stageV only flow 365 at .600, does that make much difference in power? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Which Hemi Head? [Re: astjp2] #1725509
02/24/15 05:28 AM
02/24/15 05:28 AM
Cab_Burge Online work
Cab_Burge  Online Work
If you use the old formula of 2 HP per CFM that is 140 HP, correct I've seen that on swapping wedge heads with the same combustion volume on the same short block with no other changes. Actually on the higher compression motors that I did the same swap on with the same heads, Indy SR M.W. compared to 440-1 CNC ported with 30 CFM differences the higher compression motor made more HP per CFM than did the lower pump gas compression ratio motor, not the same short block on both motors either IHTHs
Re: Which Hemi Head? [Re: Cab_Burge] #1725510
02/24/15 08:38 AM
02/24/15 08:38 AM
Dragula Offline
Dragula  Offline
Indy Hi-Po
Re: Which Hemi Head? [Re: Cab_Burge] #1725511
02/24/15 11:27 AM
02/24/15 11:27 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Wouldn't that be an efficiency thing? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Which Hemi Head? [Re: astjp2] #1725512
02/24/15 02:20 PM
02/24/15 02:20 PM
dogdays Offline
dogdays  Offline
Exactly, the increased power per cfm comes from the increased thermodynamic efficiency of the increased compression.
R.
Page 3 of 3 1 2 3
