Re: Which Hemi Head?
[Re: Mopar_Rich]
#1725501
01/28/15 07:55 PM
01/28/15 07:55 PM
Posts: 35 Down under
OUTLAW565
Down under
As for flow numbers i think the NRE X1 H2O Hemi heads exceed the Millenium heads don't they?
Yes they do and so do the BAE fat heads. But these are both billet alcohol heads not made for street use.
NRE X1 H20 heads have water passages. My mate has a set at his shop at the moment that are going on a burnout car.
[Re: OUTLAW565]
#1725502
01/28/15 10:03 PM
01/28/15 10:03 PM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
My ported Canfield heads are in down at the shop. These are the Indy Hipo heads. When I get down there and pick them up I will get them flowed. They claim 480cfm and I will have $3400 into them..I only need 440cfm or so to hit my goal.
As for the eddy heads, got to see a set Saturday, they don't even clear the rivets on the Cometec gaskets...Keep them!
[Re: gsmopar]
#1725504
01/29/15 02:35 AM
01/29/15 02:35 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Clear the rivets?
Yeah Cometic has not figured out that the brass rivets that hold the MLS gasket layers together should be moved farther out. It's just one of those things you have to look for that the rivet isn't caught between the head and block. No biggie, I just remove the offending rivet and move on.
[Re: gsmopar]
#1725505
01/29/15 08:50 PM
01/29/15 08:50 PM
Dragula
Clear the rivets?
$3400 for 480cfm, sign me up! Which Indys are these?
Hipo heads...It lists them with full porting to be 440-480cfm I can post numbers when I get them flowed.
[Re: Dragula]
#1725507
01/30/15 11:09 AM
01/30/15 11:09 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
The MP heads don't clear the rivets on Cometic gaskets either...no big deal. Just remove the rivet. That's a pretty poor reason to not use a set of heads.
[Re: an8sec70cuda]
#1725508
02/24/15 12:36 AM
02/24/15 12:36 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
So I see that the FHO stageV cnc ported heads flow 435ish, my stock replacements stageV only flow 365 at .600, does that make much difference in power? Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1725509
02/24/15 05:28 AM
02/24/15 05:28 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
If you use the old formula of 2 HP per CFM that is 140 HP, correct I've seen that on swapping wedge heads with the same combustion volume on the same short block with no other changes. Actually on the higher compression motors that I did the same swap on with the same heads, Indy SR M.W. compared to 440-1 CNC ported with 30 CFM differences the higher compression motor made more HP per CFM than did the lower pump gas compression ratio motor, not the same short block on both motors either IHTHs
