usually i work out pushrod length but with adjustable rockers can i use the standard pushrods? cam is degreed and rockers lashed-i don`t see a thread hanging out the bottom-would the rocker geometry be out?
heads were milled .020 and the deck .030. so i`m .050 out of whack(pardon the australian).
what do people think-order pushrods shorter or run the standard ones.
cam has only .454 lift and 240 duration at .050.
i do have 10.52 comp in a little 273 commando
thats quite hard to do-i got .051 clearance on the intake to piston on overlap and .093 on exhaust...just don`t ask how close that 1.50 exhaust valve is to the side of the bore...it`s close...real close.
any answers appreciated.
all the best
frank.
