Page 1 of 3 1 2 3
How do I fix this? ***Updated*** #1724138
01/07/15 07:49 PM
01/07/15 07:49 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
1968 Valiant 273. Power steering.
One of the bolts that holds the steering box in place looks to have been cross threaded before I got the car. It has broken the welded "nut" away from the K-frame. I had to cut the head of the bolt off with the torch to get the box out.
Can this be fixed? See pics.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: How do I fix this? [Re: D149] #1724139
01/07/15 07:50 PM
01/07/15 07:50 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Pic 2
1999 Dakota R/T
2000 Viper GTS
Re: How do I fix this? [Re: D149] #1724140
01/07/15 08:06 PM
01/07/15 08:06 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Is the back side of the bracket blind? If not, I would just through-bolt it with Grade 8 hardware.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: How do I fix this? [Re: VincentVega] #1724141
01/07/15 08:11 PM
01/07/15 08:11 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Yes , that is a blind hole.
I am thinking about cutting the steering box mount above that bolt hole so I can weld a new nut in, then weld the metal back on to put it back the way it was. Hoping it will be strong enough.
1999 Dakota R/T
2000 Viper GTS
Re: How do I fix this? [Re: D149] #1724142
01/07/15 08:15 PM
01/07/15 08:15 PM
pennsylvania
poboyengineering Offline
pennsylvania
The way those mounts move around in use it seems like the easiest way would be to cut the factory welds and do the repair in a vise. Then when it goes back on, gusset the heck out of it. Check the handling section here for the particulars.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: How do I fix this? [Re: poboyengineering] #1724143
01/07/15 08:24 PM
01/07/15 08:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Blow the rest of the bolt off with a torch. Find the correct size hex nut. Drill the existing hole large enough to fit the hex nut. use a long bolt in the nut so you can hold it in place in the hole - tack it in place then weld it completely. Grind it flush. DONE.
Re: How do I fix this? [Re: Stanton] #1724144
01/07/15 08:30 PM
01/07/15 08:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
not at all skilled in welding but this is what I would ask a welder to do
Re: How do I fix this? [Re: Stanton] #1724145
01/07/15 09:02 PM
01/07/15 09:02 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
All good ideas.
I have no problem with welding.
Stanton. The problem with doing it that way, is I won't be able to get the rest of the bolt and old nut out of the blind hole. The original "nuts" are square and would require a large hole to get it out. The hole would be much larger than a new hex nut.
1999 Dakota R/T
2000 Viper GTS
Re: How do I fix this? [Re: D149] #1724146
01/07/15 09:18 PM
01/07/15 09:18 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Possible to drill 1/4" or so holes around perimeter of square nut and then plug weld? That broken off bolt will still need to be gotten out though. Failing that, I would go in from other side as mentioned, repair through access hole, then close hole.
Re: How do I fix this? [Re: D149] #1724147
01/07/15 10:01 PM
01/07/15 10:01 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
super easy fix...
Re: How do I fix this? [Re: charles6970] #1724148
01/07/15 10:12 PM
01/07/15 10:12 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
The bolt is cross threaded in the nut. SO, I have to get the nut out.
super easy fix... Care to elaborate?
1999 Dakota R/T
2000 Viper GTS
Re: How do I fix this? [Re: D149] #1724149
01/07/15 10:24 PM
01/07/15 10:24 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
That is what I would do...
Pick up another square nut at the hardware store. Don't get one that has a zinc coating applied as that will lead to more problems. Cut a section out of the top of the K frame big enough to work through. Before you weld the the piece you cut out back in mock up the steering box. Tighten everything down and weld the nut in place. Then weld the plate back in and grind. It would be undetectable if welded and ground correctly.
...FAFO...
Re: How do I fix this? [Re: charles6970] #1724150
01/08/15 01:34 AM
01/08/15 01:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
super easy fix...
Ya gotta love the morons that post these replies. Yeah, "super easy fix" ... but its a secret !!!
Re: How do I fix this? [Re: Stanton] #1724151
01/08/15 01:58 AM
01/08/15 01:58 AM
SW CO
HemiSportFury Offline
SW CO
I would use a Helicoil.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: How do I fix this? [Re: HemiSportFury] #1724152
01/08/15 02:11 AM
01/08/15 02:11 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Does it really matter if you leave the remnants of the old nut and bolt in the bracket? Won't do any harm !!
Re: How do I fix this? [Re: Stanton] #1724153
01/08/15 02:14 AM
01/08/15 02:14 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Helicoil is out of the question - nothing to put it in, the original nut is broken loose.
Square nuts are hard to find - with a fine thread ... impossible.
Re: How do I fix this? [Re: Stanton] #1724154
01/08/15 02:24 AM
01/08/15 02:24 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I would cut the blind side of that bracket
off with a cut off tool, then do the repair.
Then weld the cut out section back on.
Re: How do I fix this? [Re: D149] #1724155
01/08/15 02:35 AM
01/08/15 02:35 AM
smyrna,tn
draginmopars Offline
smyrna,tn
Pic 2
is the lower right side cracked?
if so, can you find another k member
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: How do I fix this? [Re: draginmopars] #1724156
01/08/15 03:00 AM
01/08/15 03:00 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Pull the k-member (it's a perfect time to get it clean - if you were close to me I'd put it in my hot tank for you). Cut the bracket open and replace the nut. It may seem extreme to pull the k-member, but the metal needs to be clean for the weld and the welding will be much easier up on a bench.
Re: How do I fix this? [Re: Jim_Lusk] #1724157
01/08/15 09:53 AM
01/08/15 09:53 AM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
I want to avoid pulling the K-frame if possible so I don't have to get an alignment after the work is done.
I will get it all cleaned up today and make sure there are no cracked welds on the steering box mount. If there is, I will try to fix them on the car too.
In the end, if the K-frame has to come out, so be it.
Thanks for all the help. I will update on how things go.
1999 Dakota R/T
2000 Viper GTS
Page 1 of 3 1 2 3
