Re: tranny experts, Got a question
[Re: 71valiant]
#172403
12/21/08 06:39 PM
12/21/08 06:39 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I would suspect a linkage problem, crawl under the truck and observe the linkage as someone sits in the cab and shifts it through all of the gears; look for lost motion from worn or missing plastic bushings in the linkage.
If the linkage is tight disconnect the linkage from the transmission lever and shift it by hand; check for looseness in the lever between detents.
