question about 70s Darts width between wheels
#1724010
01/07/15 04:35 PM
01/07/15 04:35 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Is it just me or it seems the distance between wheels in front WIDER, than the rear wheels.
If so... why ?
Re: question about 70s Darts width between wheels
[Re: MuuMuu101]
#1724014
01/08/15 12:38 PM
01/08/15 12:38 PM
NachoRT74
Valencia, España
MMMMMM interesting!!!
yes I was talking about 73 and lates. But I thought was also something common on earliers
I think diff is way more than an inch ?
[Re: NachoRT74]
#1724015
01/08/15 01:00 PM
01/08/15 01:00 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Have you looked at actual factory specs or gotten out your tape measure and actually measured it ?
I'm pretty sure it's not the only model that the track width is wider on the front than the rear and it may have been done that way for a reason ?
Have you asked this in the handling forum, they would have a definitive answer I am sure.
[Re: JohnRR]
#1724016
01/08/15 03:08 PM
01/08/15 03:08 PM
NachoRT74
Valencia, España
no, just asking about what visually is obvious... and reason why could be. Never though could be the front disc setup making that, but wondering if also another reason now
[Re: NachoRT74]
#1724018
01/08/15 06:49 PM
01/08/15 06:49 PM
JohnRR
And when you "upgrade" to disc brakes on an earlier A-body with the 73 up parts... your front wheels are noticeably outward! Take a look at your local car cruises, you'll be able to pick them out. Well, maybe not where you are....
Hard to see 67/72 A bodies still with front drums locally. They are normally already converted, since they use to be daily drivers, so disc conversion has being a common demand for them
The track width shouldn't be different drum vs. disc when original model year correct parts are used.
[Re: JohnRR]
#1724020
01/09/15 02:39 AM
01/09/15 02:39 AM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
It's when you put the complete '73 up disc brakes on a 67 to 72. It's very noticeable, and wrong size tires will hit the fender.
[Re: MuuMuu101]
#1724022
01/09/15 12:10 PM
01/09/15 12:10 PM
NachoRT74
Valencia, España
I think 8 1/4"
8 3/4 wasn't available to A bodies since 73. I think 8 1/4 was the bigger
[Re: NachoRT74]
#1724023
01/10/15 04:46 AM
01/10/15 04:46 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I think 8 1/4"
Look at the rear of your car if there are bolts on the housing then it's either a 7 1/4 or 8 1/4. The 8 1/4 is more oval looking. If it's smooth and half a hemisphere it's an 8 3/4. I don't believe they're all the same width.
Reference:
[Re: MuuMuu101]
#1724024
01/10/15 12:36 PM
01/10/15 12:36 PM
NachoRT74
Valencia, España
I know that pic LOL... is not my car.
