Build sheets in LA cars #1723687
01/07/15 01:27 AM
01/07/15 01:27 AM
washington
TA Wanted Offline OP
washington
Just curious if build sheets were found in the LA cars more or less than the Hamtramck cars?
Thanks for the help on this!
Re: Build sheets in LA cars [Re: TA Wanted] #1723688
01/07/15 01:37 AM
01/07/15 01:37 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Less, LA plant had a no trash in car policy, so many build sheets where removed from the cars before they where delivered to the dealers.
Re: Build sheets in LA cars [Re: 67vertman] #1723689
01/07/15 03:13 AM
01/07/15 03:13 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
My one owner, unmolested 71 Duster 340 was LA built and it never had one. Very common for LA built cars to not have one. I only found a small scrap piece stuffed in the metal cavity behind the sail panel.
There was a really good thread about LA built cars in the restoration section a year or two ago.
Re: Build sheets in LA cars [Re: NV69B7RR] #1723690
01/07/15 03:21 AM
01/07/15 03:21 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I'm generally not a very lucky person, but for some reason EVERY LA built car I have owned, has had a broadcast sheet still in it! A couple of '71 B-bodies and a couple of '70 B-bodies...
Re: Build sheets in LA cars [Re: 70440+6bbl] #1723691
01/07/15 04:43 AM
01/07/15 04:43 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Same with my 1968 GTX Los Angeles plant built, no buildsheet. My car is a one owner car as well and was totally unmolested when purchased. I have had the carpet and interior out and nothing.
Re: Build sheets in LA cars [Re: SCATPK] #1723692
01/07/15 11:58 AM
01/07/15 11:58 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The broadcast sheet in my 1970 LA built Dart was for a car 266 VINs earlier than mine. I still need to check under the carpet for another one.
Re: Build sheets in LA cars [Re: Alaskan_TA] #1723693
01/07/15 01:02 PM
01/07/15 01:02 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
My '71 Duster was LA built. I've talked to previous owners. No build sheet! To bad, I do wish it had one!
Re: Build sheets in LA cars [Re: Alaskan_TA] #1723694
01/07/15 03:30 PM
01/07/15 03:30 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Did that other car have the same color and trim level seats?
Re: Build sheets in LA cars [Re: NV69B7RR] #1723695
01/07/15 04:45 PM
01/07/15 04:45 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Admiration For Multiple Carburetor Vehicles...
Re: Build sheets in LA cars [Re: autoxcuda] #1723696
01/07/15 07:06 PM
01/07/15 07:06 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Same interior code, different outer body color.
