six pack kill bleeds
#1723523
01/06/15 10:48 PM
01/06/15 10:48 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
Have been reading many of the post on six packs and read about reducing kill bleed size to start opening the outers quicker. Would blocking off one of the carbs kill bleed give the same effect? Say the front carb only and since they have a T fitting inline hose would give signal to other? Would it almost be a progressive transition? Or it could just be this Zero degree weather frosting my Brain
Re: six pack kill bleeds
[Re: 5126brl No more]
#1723524
01/06/15 10:56 PM
01/06/15 10:56 PM
Posts: 12,138 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have never tried that. But I have worked on several that would open late or erratically because the bleeds were clogged.
Are we to assume that you have tried the spring kits and they still don't open quick enough even with the lightest springs? And that you have made sure that the other usual culprits are not a problem?
Master, again and still
[Re: 6bblFLASH]
#1723526
01/07/15 09:54 AM
01/07/15 09:54 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Something I always thought would work that I wanted to try is......... a small barrel valve or even a little needle valve in line on the vacuum hoses. Would make the bleeds totally tunable with the turn of a knob. You would just need to make them all a little oversized then adjust down.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1723527
01/07/15 12:47 PM
01/07/15 12:47 PM
Posts: 1,318 Ohio
jlatessa
Ohio
Wow flash...great idea, and a heck of a lot easier than spring fiddling. I'm going to figure something out and try it when summer comes around here...Thanks,
Joe
PS Where're you at in NE OH, I'm in Kirtland
[Re: 572charger]
#1723532
01/08/15 01:27 PM
01/08/15 01:27 PM
Posts: 1,318 Ohio
jlatessa
Ohio
Wait a minute, let's rethink this, if we're trying to slow the bleed-off of vacuum, to make the secondaries open quicker, aren't we working on the wrong side of the diaphragms by putting a restriction in the vacuum lines from the center carb???? We need to have the restriction in the channel from the vacuum pods to the secondaries' orifice to the venturis.... Or am I crossed up?? Joe
