engine assembly Q's..crank and pistons
#172138
12/21/08 02:19 AM
12/21/08 02:19 AM
Assembling a motor and have the crank in and torqued. I cant turn the thing at all! I used plastiguage (i know be easy on me guys) to just check on the clearances and they all spec out OK. BTW it has a rope style rear seal..I was just worried if this is common or if there is a definite problem? The piston worries are because when checking some ring gaps i noticed i could move the piston a good bit side to side (being pin sides) in the bore but not up and down when the piston is completely in the bore. It's over .030 now and i had the hyperutectic pistons pressed on the rods. Can these pistons bend out of shape when the pin is pressed through the rod? I don't assemble too many motors..especially on my own so not too sure what the "norm" is for fitments on this stuff. Thanks Marc
Re: engine assembly Q's..crank and pistons
#172139
12/21/08 02:52 AM
12/21/08 02:52 AM
RapidRobert
piston issue is OK, it has that clearane on the non thrust sides. On the crank, your upside down on a stand right? I'd for sure pull the caps, check for anything amiss, install/torque the caps from rear to front except #3, install it(3) snug & tap the crank front & rear to line up the(#3) thrust bearing halves then torque it (#3) too. Check turning effort as you go thru this to see if you've caught it(or to pinpoint it) & you oiled the journals after the plastigage(which can be left on there).
[Re: MO_PA]
#172141
12/21/08 12:32 PM
12/21/08 12:32 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Did you start with #3? Did you set it to center the thrust surfaces? Did you try to turn in after each successive addition? Plastigage does not show taper, or misalignment. Take it apart and try to turn after each. It should be able to be turned with a wratchet or breaker bar with very little effort, even with a rope seal in place. The last part should be the lower rear main seal retainer. Torque each fastener in 3 steps, ariving at the final value in one smooth motion.
[Re: fox]
#172143
12/21/08 01:32 PM
12/21/08 01:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Make sure all the caps are on right! Locking tabs go together.
This and just snug the mains, tap the crank fore and aft to align the trust on #3 then torque to spec (I use the 3 step method) then turn the crank bewtween each main cap after its tight
[Re: fastmark]
#172146
12/21/08 05:58 PM
12/21/08 05:58 PM
Posts: 8,917 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
When they put the main cap in the grinder to cut the ends, it may not have been square.
Not likely. The way the fixture works its virtually impossible to grind it out of square. Even if they did, the bolts would hold it straight.
The caps could be on backwards though - although its hard to imagine.
[Re: Stanton]
#172147
12/21/08 08:21 PM
12/21/08 08:21 PM
Update.. i switched from the rope seal to the rubber seals and tore it down and rechecked everything. I can turn it with a breaker bar easily and i dont feel any tight spots or anything grabbing, but i cant spin it by hand. Its about 35-40 degrees in my garage and i'm using some thick lucas assembly lube. I think i'm in the clear as everything does check out like it did before, i just cant move it by hand.
