Re: 98 dodge 2500 4x4 v10 oil pan Help please
[Re: chargers777]
#1721158
01/04/15 01:38 AM
01/04/15 01:38 AM
Posts: 516 ND
dodgedon
ND
You asked this question a few months ago. Mine will do this also. I thought it might be valve train noise/oil pressure issues. I think you said it would do it at start up also. When mine sits for a few days it will rattle at first start up of the day. Just like when you change the oil and filter and the motor oil has drained back you get that lifter noise for a few seconds. But also on heavy acceleration when the tach gets up to about 3000 on mine it will sound the same way. At that point I don't see any change in oil pressure. Some one told me once it could be the pressure relief spring but I think you said yours was good? I have not checked mine... Any one have any thoughts on this? I feel if it was a bearing noise you would hear it tapping all the time.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#1721159
01/04/15 02:44 AM
01/04/15 02:44 AM
Posts: 516 ND
dodgedon
ND
Reading your post got me thinking about my own again and i found this TSB on a google search. Look up "V10 DCP valve" The TSB states Knocking like noise coming from engine compartment at idle or under load....
[Re: chargers777]
#1721164
01/08/15 01:36 PM
01/08/15 01:36 PM
kielbasa
my 97 never made that noise, the reason i dropped the pan was to replace it - it rusted thru!.....i also have an '03, it does not make noise either.
[Re: kielbasa]
#1721165
01/08/15 08:54 PM
01/08/15 08:54 PM
Posts: 516 ND
dodgedon
ND
I beleive the TSB only lists 98 99. Mine does not make any noise at idle after the first start up.
