finally i have figured out how to post pics here!!!!!!! <img src="/ubbthreads/images/graemlins/punkrocka.gif" alt="" /> <img src="/ubbthreads/images/graemlins/beer.gif" alt="" />
68 dart turbo 440/ world iron block 4.25 bore /3.75 stroke hemi 8 boly crank 4340 mp performance / manley pro I beam rods / Icon pistons 8.3 comp / EDDY performer heads mild work done / scott brown hyd roller cam custom grind for turbo / F.A.S.T EFI 97 lbs injectors EDDY efi manifold pro flo modified for bigger injectors / D-60 3.73 spool /325 drag radials on rear. all work done by me so far accept the cage and dash. more pics!!!!
I have never built a turbo car, but I really want to. Having said that, how will the engine be mounted? I would think mounting the turbo to the frame rail could cause problems if the engine moves at all (ie torquing out). I'm sure you have already thought that through; just wondering. Looks like a clean implementation so far. Will you be using an intercooler?
