Page 2 of 3 1 2 3
Re: New Borgeson Box install. [Re: 1fastabody] #1720505
01/07/15 12:33 AM
01/07/15 12:33 AM
Victoria B. C Canada
gold66cuda Online content
gold66cuda  Online Content
Here are a few pictures of the new box in a 1966 Barracuda, it fits very well in a narrow early abody engine compartment. Slight angle from the box toward the inner fender but the steering coupler takes up this angle no problem at all, no binding and it feels really smooth through the full rotation. I haven't powered it up yet to see how it feels in use but i am very happy with the fitment. Sorry you cant see the input shaft angle in the pictures as its under the headers but it is very slight, should have taken the pictures before I put the headers back in. Its a nice looking piece!
Re: New Borgeson Box install. [Re: 1fastabody] #1720506
01/07/15 11:43 AM
01/07/15 11:43 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Bergman, Is there any advantage to the "New" Box over the old version? I have the old version that I have not installed yet and would like to know if there is any benefit to make a switch to the new one? Thanks
The new box is smaller, but feels the same. Just a product evolution on Borgeson's part.
Re: New Borgeson Box install. [Re: BergmanAutoCraft] #1720507
01/08/15 10:25 PM
01/08/15 10:25 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
interesting video on borgeson how they make boxes https://www.youtube.com/watch?v=QXm7Wq64u2A
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: New Borgeson Box install. [Re: sublimehemi] #1720508
01/09/15 06:28 PM
01/09/15 06:28 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Right you are, quite interesting. Worth viewing
Re: New Borgeson Box install. [Re: Sxrxrnr] #1720509
01/09/15 10:56 PM
01/09/15 10:56 PM
Kings Beach, CA
tahoechallenge Offline OP
Kings Beach, CA
Good video, thanks for sharing. I hope to drive the car this weekend. I am moving a little slow from a pulled muscle in my back. The fitting offered by Bergman will be a big help. There is not much available in the 16x1.5 inverted flare. Borgeson offers complete universal type hoses that may or may not fit. They also sell one conversion fitting that converts to -6 jic. The factory hose is -5, so that is not much use. I made my own fitting on my lathe for the supply line, and found a metric tubing nut from O'reilly's for the return. While I was at it, I made a threaded extension to use with sector support kit from Firm Feel. If my back cooperates I will be driving the car soon!
Re: New Borgeson Box install. [Re: tahoechallenge] #1720510
01/10/15 05:53 AM
01/10/15 05:53 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Will this box withstand the higher pressure of the PS pump on a 5.7 Hemi?
2 Demons...no, not my kids!
Re: New Borgeson Box install. [Re: 4speeds4me] #1720511
01/13/15 09:22 AM
01/13/15 09:22 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I installed this box in my bb duster. The worst part was getting the stock box out of there. I like the way it looks and fits. Can't decide what I want to do for lines and a coupler. I already modified my column for a ujoint since there as no room for the stock coupler.
Re: New Borgeson Box install. [Re: JAMESDART] #1720512
01/13/15 11:10 AM
01/13/15 11:10 AM
Long Island, NY USA
Long Island, NY USA
I have both if you choose.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720513
01/17/15 01:13 AM
01/17/15 01:13 AM
Kings Beach, CA
Kings Beach, CA
Update: I drove the car this evening. The box felt tight, but the steering effort was very light. After a few minutes of driving back and forth between two streets the steering started acting funny. I drove the car back home and discovered that the fluid was overheated. The pump I am using is out of a 99 Durango. I think the pressure is too high for the new box. I am in the process of adjusting the pump pressure. Hopefully this fixes the overheating and light steering effort.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720514
01/17/15 09:30 AM
01/17/15 09:30 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Did you properly aerate the box and pump before driving?
I remember after I installed my 1st gen Borgbox the fluid was foaming quite a bit after first startup.
I let it sit for a few minutes for the foaming to reside, fill it up a bit then start it up again and turning the wheel lock-to-lock.
Had to do this 2 or 3 times before the foaming stopped and oil was at it's proper level.
Re: New Borgeson Box install. [Re: BigBlockMopar] #1720515
01/17/15 02:10 PM
01/17/15 02:10 PM
Kings Beach, CA
Kings Beach, CA
I think that could have been part of the problem. I ran the steering box through it's full travel many times (engine running) before I put the pitman arm on. I probably should have taken it easier on the car when I took it for the first drive. The fluid was aerated when I rechecked it. I know heat does not transfer effectively through aerated oil.
Re: New Borgeson Box install. [Re: tahoechallenge] #1720516
01/17/15 02:31 PM
01/17/15 02:31 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Why? Bleeding out boxes isn't rocket science and sounds like you did it correct and then some.
At the dealership a rack or box was slapped in, cranked a few times left to right on the lift to get the air out, quick trip around the block to make sure the wheel was straight and done.
"I think its got a hemi"
Re: New Borgeson Box install. [Re: gdonovan] #1720517
01/17/15 04:28 PM
01/17/15 04:28 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Make sure the car is on its wheels to bleed it out. This will ensure that all the internal valves funtion. If you don't do it this way, you will end up with aireation issues and the fluid level will drop.
Carl Kessel
Re: New Borgeson Box install. [Re: BergmanAutoCraft] #1720518
01/18/15 12:47 AM
01/18/15 12:47 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
the BERGMAN fitting only works with the older pressure hose, right? I have a new hose, the 73+ style. do you have a pic of the older style hose with your fitting? I don't really like the look of the borgeson hoses but I think those might be a better option for me. if they will work. I think a
Re: New Borgeson Box install. [Re: JAMESDART] #1720519
01/18/15 01:00 AM
01/18/15 01:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I took some weight of the car but left wheels on the ground,with engine off, filled to line, turned lock to lock several times, fill to line, cycled wheel again, did that until it was no longer taking fluid. Drove it around town, topped it off one more time and never touched it again.
Mopar to the bone!!!
Re: New Borgeson Box install. [Re: 72Swinger] #1720520
01/18/15 02:47 AM
01/18/15 02:47 AM
Kings Beach, CA
Kings Beach, CA
Today I adjusted the pressure on the pump. The steering feel was better, but it had no effect on the overheating issue. I am not using a p/s cooler, so I think that will be the next thing to do. I may contact Borgeson and see if they have any ideas. I checked the hoses for restrictions and found none. The flow through the new steering box seems good and unrestricted. I did some reading on the different displacements of Saginaw P style power steering pumps and can not find anything drastically different with the pump I am using.
Funny how these little things can side track a project...
Re: New Borgeson Box install. [Re: tahoechallenge] #1720521
01/18/15 03:01 AM
01/18/15 03:01 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The 99 Durango was a steering box truck wasn't it? Didn't have R&P until 2000?
Re: New Borgeson Box install. [Re: 72Swinger] #1720522
01/18/15 03:06 AM
01/18/15 03:06 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Also was this a junkyard pump? The pressure relief valve could be clogged and or stuck.
Re: New Borgeson Box install. [Re: 72Swinger] #1720523
01/18/15 01:04 PM
01/18/15 01:04 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
2x Durango is r&p, 4x is box. I also plumbed in a cooler on my car when I put the new FF pump and box in. The new Borgeson unit is looking atractive with its smaller profile than the earlier unit. After watching the video and getting a ah ha moment, now I understand the cost factor for them. 3 units cut up to make one.
Carl Kessel
Re: New Borgeson Box install. [Re: CKessel] #1720524
01/18/15 03:23 PM
01/18/15 03:23 PM
Kings Beach, CA
Kings Beach, CA
The Rock Auto web sight does not differentiate between the 4wd and 2wd models. I don't know about Chrysler. When I was shimming the pump yesterday, I compared the relief valve and the orifice hole in the output fitting to a Saginaw pump that came with the car. (This part is sometimes referred to as a "flow control valve".) Edit: The Durango had a .143 orifice, and the original pump was .130. I learned that the 4wd guys will change out the output fitting to one with a .143 orifice to increase flow for the hydraulic ram style steering. Guys who use Saginaw pumps with a Mustang 2 rack will change out the flow control valve to one that reduces flow to 2gpm. I do not know what size the orifice is in that valve.
Edit: I bought the reduced flow valve and it measures .113.
Just for background: I never had any problem with heat using the Durango pump with the factory stage 3 box. I had around 4k miles on this setup. To fix the overheating with the Borgeson box, I am going to add a steering cooler. If it still runs hot I will change the flow control valve to the 2gpm style.
Page 2 of 3 1 2 3
