chamfered bearings????
#1720461
01/02/15 11:05 PM
01/02/15 11:05 PM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
What are chamfered bearing good for???? Thanks
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: chamfered bearings????
[Re: sixty7gtx]
#1720462
01/02/15 11:17 PM
01/02/15 11:17 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
They are not good for anything if your crank is not radiused. They are a necessity on custom ground cranks with large radius. If stock bearing is used the rods will lock together with stock bearing.
1969 Dodge Charger
1969 Dodge Superbee
[Re: sixty7gtx]
#1720465
01/02/15 11:36 PM
01/02/15 11:36 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Most likey stock bearing will not clear , Some old timers used to use a bearing knife and make ther own.
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#1720466
01/02/15 11:38 PM
01/02/15 11:38 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
M U S T R E S I S T
[Re: sixty7gtx]
#1720467
01/02/15 11:39 PM
01/02/15 11:39 PM
JohnRR
U.S.S.A.
I Have the Eagle 4340 crank with a 4.375 Stroke.
Yes you need chamfered bearings , and they should clear the chamfer and not need FURTHER chamfering by hand , if they do call eagle and they will fix it .
[Re: Dunnuck Racing]
#1720470
01/06/15 03:23 PM
01/06/15 03:23 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Aftermarket crankshaft have a,radius cut on the journal instead of an undercut. The chamfer is to clear the radius. Keith
x2. B wedges and some small block cranks will have the issue with the radii interfering with the bearings. ...and sometimes the ones sent with the kits need more chamfer than was put on them so you shouldn't assume all's well no matter who supplied it.
[Re: moper]
#1720471
01/06/15 03:36 PM
01/06/15 03:36 PM
sixty7gtx
Connecticut, USA
Here is one more. Do chamfered bearings have a shorter life?
[Re: dogdays]
#1720474
01/06/15 07:58 PM
01/06/15 07:58 PM
JohnRR
U.S.S.A.
I think JRR meant if chamfered bearings do not last as long would you have the radiused fillets ground off the crank?
It floors me that some people would actually have to think about that.
R.
[Re: sixty7gtx]
#1720475
01/06/15 09:47 PM
01/06/15 09:47 PM
Posts: 7,664 IN
ahy
IN
The radius in the crank makes it stronger (fatigue strength)... the chamfered bearing has a small reduction in effective bearing area which (in theory) could result in a small reduction in bearing life. In practice, I wouldn't think it is noticeable or meaningful. A very small tradeoff to get a stronger longer lasting crank.
[Re: sixty7gtx]
#1720480
01/08/15 01:04 PM
01/08/15 01:04 PM
JohnRR
U.S.S.A.
Last i checked the s/s Hemis are running Mercedes, maybe Honda, bearings, very small and narrow. It would depend on the rod-piston weight-rpm plus good oil film. I would never worry about chamfered bearings
Thank you for your message!!!!!!!!
I take care of my Engine. Never beat on it. I have approx. 1000 miles on my motor. I put brad penn oil in it. What do you think of synthetic oil???
what a sad life the car is leading , drive it like it was built to be .
From what I have been told you need to have over 5k miles before you think about switching to synthetic , and you need to make sure it's flat tappet friendly oil .
