Re: Putting my 5.9 magnum into my coronet what do I need?
[Re: 79machocharger]
#1720403
01/02/15 09:20 PM
01/02/15 09:20 PM
Posts: 5,443 ME
79machocharger
ME
#1720406
01/02/15 10:01 PM
01/02/15 10:01 PM
Posts: 3,344 Central TX
roe
Central TX
I didn't see you mention the fuel pump. Plumbing in an electric, or buying the snout extension to stay mechanical?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
#1720413
01/03/15 11:58 AM
01/03/15 11:58 AM
roe
Central TX
I have the Dougs headers onbmine (D453) and love them. Great plug access, great bolt access, thick flanges so no warping or leaks, fit great, no linkage goes through the tubes so install is a breeze, they dont hang low, thick tubes and nice ceramic coating keep underhood temps down. All the benefits touted about TTI's but significantly lower cost.
#1720414
01/03/15 12:21 PM
01/03/15 12:21 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Yah I wasn't sure how all the linkage was going to hook back up. Also should I go with a different torque converter or will my factory 318 one be fine? Should any mods be done to the transmission.
I'd probably step up a little on the converter. You are probably picking up 50-75hp and some torque. If this is mainly street driven call somebody like Turbo Action in Fl and see what they recommend. As for a carb, almost anything in the 600-650 range will work. Nice car... I'd have a really hard time NOT making it a 440-6 4 speed.
#1720419
01/04/15 08:26 PM
01/04/15 08:26 PM
Posts: 5,443 ME
79machocharger
ME
So checked the motor mount situation and my original 318 motor mounts will work on the driver side like you said with a spacer but the passenger side one is missing a hole in the bracket where I need one. Should I drill it out to make it work or should I buy a different one?
