ring end gap-what do people think? #1720360
01/02/15 07:29 PM
01/02/15 07:29 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
rebuilding a 273 with a standard bore 3.625
i have egge pistons 10.5 and the rings they supplied are not filebacks but they measure .010 for top ring and .008 for second.
i think this is too tight.
what do others think?
total stock commando 273 build.
thanx in advance
frank.
Re: ring end gap-what do people think? [Re: 1cuda] #1720361
01/02/15 07:49 PM
01/02/15 07:49 PM
Az
Crizila Offline
Crizila  Offline
Az
thanx in advance
frank.
When all else fails, go with .004" per inch of bore. Too tight = broken. Too loose = uses a little bit of oil.
Fastest 300
Re: ring end gap-what do people think? [Re: Crizila] #1720362
01/02/15 07:56 PM
01/02/15 07:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Yes that is to tight. Go with .016" Top .014" Second.
Re: ring end gap-what do people think? [Re: Biginchmopar] #1720363
01/02/15 08:35 PM
01/02/15 08:35 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
that`s what i thought-that`s what i`ve done in the past.
i`ve heard about not having the second ring too tight as well to eliminate ring flutter caused by trapped pressure between the rings...is this true?
should i run both at .014 or go with .014 on the top and .012 on the second?
3.625 is a small bore.
thanx for the replies.
all the best
frank.
Re: ring end gap-what do people think? [Re: Crizila] #1720364
01/02/15 08:36 PM
01/02/15 08:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanx in advance
frank.
This is the standard I use... the ring companies do
a LOT more testing on end gap than I ever did.. I've
never broke a ring
Re: ring end gap-what do people think? [Re: MR_P_BODY] #1720365
01/02/15 08:58 PM
01/02/15 08:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree to tight. .004 per inch of bore is right for a normal setting. I would rather be a tad loose then to tight on ring gaps. Ron
Re: ring end gap-what do people think? [Re: Biginchmopar] #1720366
01/02/15 11:01 PM
01/02/15 11:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
One trend is a wider second gap.........Mine are .018-.027.fwiw.
Re: ring end gap-what do people think? [Re: 1cuda] #1720367
01/02/15 11:35 PM
01/02/15 11:35 PM
NC
440Jim Offline
440Jim  Offline
NC
IMO,
0.014" on the top and 0.010" on the second would be fine in that application. However, you won't notice any difference with 0.016" top and 0.014" second, or even 0.014" top and 0.012" second.
