Re: Locked distributor advance
[Re: RobbMc]
#172054
12/22/08 02:23 PM
12/22/08 02:23 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
My distributor has been locked for 6 years..Compression ranging from 11.8 to 13.3....no start retard or anything, has never kicked back, and start it with the key just like from the factory. I like it, makes tming it easy(if your light is good)
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: chryco]
#172059
12/23/08 12:41 AM
12/23/08 12:41 AM
will the lean burn distributor work for a locked distributor?
#172060
12/23/08 01:15 AM
12/23/08 01:15 AM
Posts: 6,183 Bridgeport, WV
Michael
Bridgeport, WV
10-4
[Re: Jeepmon]
#172066
12/29/08 10:56 AM
12/29/08 10:56 AM
Posts: 4,209 New York
polyspheric
New York
Yes, every engine that idles above 3,000 RPM will do quite well with locked advance. Others... not so much.
If your engine runs the same with and without advance, there is something wrong with your cam, carb or both.
Boffin Emeritus
