I have two original 120 degree faces with black backgrounds and white letter, one is a oil pressure from zero to eighty lbs. and the other is water temperature from 100 to 280 F I called and ask the Sun Pro tech. to see if they where the same company and the tech said in a roundabout way that Sun had been part of the company at one time a long time ago before Snap On bought Sun instruments and then sold them off to Bosch
![](/ubbthreads/images/graemlins/shock.gif)
He gave me several of the Sun Pro senders part numbers and the ohm readings of them to see if they would work with thier gauges now. I have a bunch of older electrical sending units but none of the ones I have now read the way he says they should at zero pressure or room temperture, between 70 and 80 F
![](/ubbthreads/images/graemlins/smilie_help.gif)
I would like to use them in my 1966 Dodge Coronet Deluxe street car I'm building to make it look like they did when I was getting started in hot rodding a long time ago in the mid 1960s
Thanks in advance
![](/ubbthreads/images/graemlins/thumbs.gif)
